2010 Full Dezod Alpha Series build... !!UPDATE!! NEW PIX
#44
what you running Management wise??? and another, what rev you dropping at? I want to try a set of slicks, it'll be the first time ever and I just don't want to make like umpteen passes just to figure a good launching point.. Since you're like the only one i know so far with slicks i appreciate the info..
#50
btw, nice job on the cable conversion silvrtc300. my friend did the same swap on his tc.
#51
Yup i got both bud! If you want, send em to my house, I can get oem wheel bearing for like 35 a peice. then ill press them in for free!
Then you have two spindles new wheel bearings and ur hubs ready to rock
#53
What ever happen to this one? Anyone have it? http://www.mcssl.com/store/oandjperf...5783ea0a7bec4a
#58
True dat.
pauly d.. any updates on the aem v2.
Me and one of my guys are working on a true a/c fix. for it.
It involves the high side pressure switch. basically once the high side line meets a certain pressure if sends a ground signal. Were going to intercept that tap that into a relay which will act like the on and off switch for compressor.
The only issue would be the car would still be idling high since the idle comp map would still think a/c is on.. But a/c will work. On the next harness maybe you could just leave the flying leads there.. =D
sorry for thread jack
