2010 Full Dezod Alpha Series build... !!UPDATE!! NEW PIX
#61
it's all good.. I would be working on a solution for this as well but I have no reason to, since I have nothing under the dash nor no A/C to run..
True dat.
pauly d.. any updates on the aem v2.
Me and one of my guys are working on a true a/c fix. for it.
It involves the high side pressure switch. basically once the high side line meets a certain pressure if sends a ground signal. Were going to intercept that tap that into a relay which will act like the on and off switch for compressor.
The only issue would be the car would still be idling high since the idle comp map would still think a/c is on.. But a/c will work. On the next harness maybe you could just leave the flying leads there.. =D
sorry for thread jack
#72
