2AZ ECU, sensors, knock & fuel Delivery...
Old 04-15-2010, 05:51 PM
crush02342002's Avatar
Originally Posted by crush02342002
fwiw im sitting on 32% idc w/850cc big reds @ 8psi with my dinky garrett t3/t4b, last time i had over 80%idc at 11psi on the same turbo. so im just guessing i got a ways to go before i reach 80% idc. still will need to raise the fuel pressure and volume at some point otherwise that 80% idc will come real quick
forgot to add that 80%idc before was with 550cc injectors.
crush02342002 is offline
Old 04-15-2010, 06:52 PM
m6ar2cel6oTC's Avatar
Default Re: 2AZ ECU, sensors, knock & fuel Delivery...
Originally Posted by paul_dezod
If you are running on a Hydra and BC cams already, the air gap was already addressed Yev. We have had a few customers where their car would not start after installing cams. Since your car is already running, you have nothing to worry about.
I think rob is having this problem with the hydra and bc cams.
m6ar2cel6oTC is offline
Old 04-15-2010, 06:55 PM
dbrummet's Avatar
Very awesome post Paul, should help with some DIY tuning.
running 8 PSI at 11.1:1 AFR WOT with ignition timing running around 13-15 degrees of advance.
This is exactly what I get at WOT, so I am guessing this is probably the norm. This is with the Dezod S1, 550cc, 1 step colder plugs...
dbrummet is offline
Old 04-15-2010, 08:01 PM
cburglb34's Avatar
yea when i was n/a with a header i ran 3 anti-foulers to prevent a check engine, now that im turboed i keep getting a "bank 1 sensor 2 high voltage" anyway to fix this i was thinking maybe removing 1 of the foulers
cburglb34 is offline
Old 04-15-2010, 11:50 PM
ScionFred's Avatar
Great info Paul, thanks. I'm still unsure about what IRT to input into the FIC. At ~13V the stock FI's should be around 750us, my 440cc DW's are 1200us. AEM hasn't been very helpful. They told me to leave IRT at 486us because my FI's aren't much larger than stock. As near as I can tell FIC IRT should be set somewhere between 750 and 1200 but I've seen some good tuners use only 550us with on 550cc FI's. I can't believe AEM doesn't offer clear advice on this since IRT should be the first step in fuel tuning. Changing it afterwards only screws up your fuel tune.
Here is a pretty good, albeit a bit old and very technical, read on the subject:
http://www.autoshop101.com/forms/h25.pdf
The 2AZ-FE isn't listed but I'm fairly certain that it uses independent FI timing control. I found it interesting to see that the stock ecu even corrects injector pulse width based on battery voltage.
ScionFred is offline
Old 04-16-2010, 03:08 PM
B_Real45's Avatar
Paul,
My current BC cams dowel pins are extended to match the length of OEM. Should they be pushed further out to get closer to the sensor? In other words, should the air gap be the same or smaller with the BC cams?
B_Real45 is offline
Old 04-16-2010, 03:19 PM
Scionetics
KAD
paul_dezod's Avatar
The anti-fowler is causing this.
paul_dezod is offline
Old 04-16-2010, 03:20 PM
Scionetics
KAD
paul_dezod's Avatar
Originally Posted by B_Real45
Paul,
OEM or tighter Rob. If the car runs on the OEM gap, then you are good. If not, then go tighter.
Old 04-16-2010, 11:44 PM
my06tc's Avatar
I'd be curious to see how well or at it works. I know most of those simply change the ramp of the TB opening. For example, it feels faster because at 40% throttle, it opens the plate 60%....
Hmmm wouldn't say faster, the throttle feels alot more responsive,makes the car pull alot better...like a night and day difference
my06tc is offline
Old 04-17-2010, 04:16 AM
cburglb34's Avatar
k well if i run no foulers ill get a check engine lol...there no winning
Old 04-17-2010, 04:34 AM
try just two of em instead of three. I use two of the short ones
Old 04-17-2010, 07:18 PM
Scionetics
KAD
paul_dezod's Avatar
So, some more cool facts and info.
How long (spool wise) would you think it would take a 54 trim .63 A/R turbocharger to go from cruising in 4th gear in vac (10 kPA) @ 3200 RPMS to full boost of 7 PSI (145kPA) on our S1?
Answer: Peak boost was achieved at 3548 RPMS! This is a standard journal bearing turbocharger and had full spool in less than 348 RPMS. No too bad huh?
Our highest duty cycle on this particular run was about 51% at about 6K rpms on a walbro 255 and 850cc injectors
nightfox915
04-17-2015 07:06 PM
yhwhdesign
03-07-2015 02:01 AM
k1114
03-06-2015 03:43 PM
eric_m
79
03-17-2013 12:21 AM
kdanie
47
02-07-2006 05:46 AM
Quick Reply: 2AZ ECU, sensors, knock & fuel Delivery...
