2AZ-FE Removal?
#44
so i got it up and running drove it around today for about 15 min, but i noticed i have an oil leak at the rear of the motor. i put more sealant on the back of the oil pan thinking it was the oil pan but it wasnt, i cant really see where its coming from:/ also have a tiny tranny oil leak again i dont know where its coming from.
any ideas?
heres the specs:
07 tC
-06 rebuilt motor
-balance shafts delete (oil passage plugged)
-brand new 08 oem pistons & rods
-arp head studs
-new headgasket
-new water pump
-new oil pump
-clevite main bearings
-08 oem cams
thats all i can think of off the top of my head. any info would be appreciated.
oh im using Eneos trans fluid btw
any ideas?
heres the specs:
07 tC
-06 rebuilt motor
-arp head studs
-new headgasket
-new water pump
-new oil pump
-08 oem cams
#46
any ideas?
heres the specs:
07 tC
-06 rebuilt motor
-arp head studs
-new headgasket
-new water pump
-new oil pump
-08 oem cams
any ideas?
heres the specs:
07 tC
-06 rebuilt motor
-arp head studs
-new headgasket
-new water pump
-new oil pump
-08 oem cams
Curious, how much was the rebuild for stock parts vs that of a built motor?
#47
PM me^ im a college student so i didnt have enough cash for forged internals or else it would of been fully built.
Anyways im on 100 miles with the new motor. I did the initial start up with non detergent 30w mineral oil drained it, changed filter. Popped off pan and i had metal flakes and a tiny tiny little metal shaving. Is it something i should be concerned about?
Anyways popped the pan back on, changed it to 5w-30 conventional oil and ive been on that for about 80 miles, gonna change the filter and oil again to the same 5w-30 For another 250ish miles am i doing this right?
Also how should i be driving it while the rings seat and the engine breaks in?
Ive been driving like a g-ma under 3k rpms and doing a lot of engine breaking, i just dont want to do it wrong ya know? If someone could give me some more info.
#50
Would have been about 800$ difference give or take, depending on which internals you went with. I can give you a precise price list of everything that went into the motor along with cost of machine work etc. if your curious.
mikeytomas
08-06-2015 08:54 PM
