2azfe motor
mounts may vary...idk this for sure but it has been said before that a 2az from 2nd gen xb isnt a direct replacement for the tc however all thats needed is to swap out the timeing cover and maybe the valve cover.
I have a 2az sourced from an 08 or 09 camry (cant remember exact year, its one of the two) and the mounts were the same, only diff was the valve cover. where the coilpacks bolt down is raised 1/4" higher on the camry vs tc 2az.
05-06 tc pinout
http://www.dezod.com/files/ECU%20pinouts----.pdf
07-10 tc pinout
07-10 tc pinout
If the CR and vvti is the same (not sure on those years of the Rav4 and camry) you could possibly just use the long block, bolt up everything off the tC and use the tC's ECU that you already have.
crimson_sinn
09-25-2015 09:41 PM
