300 hp range.who's there and what u running
#61
My 14.33 ET was run at ~75F. Scion lists the curb weight at 3080 plus I had 60 lbs of gas, a 10" sub box & amp, sway and strut bars, turbo, cast iron manifold, SMIC, etc. and my 275lbs. I figure about 3450 lbs total.
#62
if it makes you feel better my sc still hasnt hit 300 yet. mayb after the tune.. btw the engine is fully built. once the sc goes gonna get swap out and set up for turbo. from my what i know with 2.5inch is good enough for 225-275whp and 3inch is good for 300-450whp or something like that less back press means more hp and more back press means more tq. correct me if im wrong.. last time i study about turbos about 3+ years ago.. on celica all trac
#63
unichip cannot tune closed loop for our cars so what that means is it cannot tune partial throttle the only units that can are the Emanage Ultimate and the FiC. the FiC is the more pocket friendly unit and is reliable the ultimate is more costly but has way more options.
Dude that's B.S., The Uni chip tunes in closed loop and partial throttle through the MAF sensor. It is a very good unit. Most people hate due to the lack of tuners since you need to be certified through Uni-chip. If the Uni-chip didn't make adjustments in closed loop, then tell my how I have a perfect idle in closed loop with 630cc injectors?
#64
#66
That may be, but I have spoken with Uni-chip and was told adjustments are made on partial throttle. During partial boost in closed loop it sees the difference in voltage across the maff and makes adjustments. I know If I partial boost cruising I will dip in the low 13's afr.
#68
A cold engine idles in open loop for a very short time before entering closed loop where it remains from idle to the load point where open loop is entered. Unichip, Greddy blue, EMU, etc. can sort of tune closed loop by providing injector size correction. However they can't change the target AFR from stoich. At least not sustainably. The AFR may dip below 14.7 but the ECU will immediately attempt to correct this back to 14.7. The only way it can't is if the max fuel trim is exceeded, in which case you'll get a CEL. You might see richer than stoich closed loop more on a new tune but eventually the ECU will adjust the long term fuel trim to compensate and you'll be back to stoich or adding fuel to your tune. It's simply not a good way to "tune" closed loop AFR.
The FIC differs by using circuitry that modifies the primary O2 sensor signal to the ECU. By making the O2 sensor read leaner than the actual AFR it causes the ECU to add fuel to acheive what it thinks is stoich AFR when in fact it is now richer. OBD data logs will show 14.7:1 AFR (1.00 Lambda) but your wide band gauge will show the true AFR targeted by the FIC. There are other units that can tune closed loop AFR such as the Split Second Enricher and URD AFR modifier but that's all that these units do. Adding one of these to a Unichip or Greddy piggy would provide the sustainable closed loop fuel enrichment needed.
I hope this clears things up.
#69
EXACTLY!..good job Fred!
#72
old thread i know but that would be nice if we had a map sensor, but we dont. We have a MAF sensor no MAP sensor =) I ran into that problem with the unichip, just purchased the sse life is good.
#73
im running a holset hy35 turbo with a turbo toyotas mani and 3 inch exhaust greddy profec b boost controller with an emanage ultimate and 500cc injectors at 10 psi. full boost at 3k rpm LOVE my set up!
Erager09
04-23-2015 01:50 PM
