378whp @ 20psi.. does that sound right?
So i just got my car back tonight. I made 378whp @ 20 psi. I was told i was maxed out with my set-upTo me that seems kind of low with my suporting mods. could be wrong, what do you think?
aem ems
set-up
gt35r
tt stage 2.1 kit
el mani
3" dp w/ megan drift spec cat-back
cc stage 3 clutch
fidanza flywheel
motor
cp pistons
ki rods
.5mm overbore
fuel
dezod return system
rc 750cc's
aem ems
set-up
gt35r
tt stage 2.1 kit
el mani
cc stage 3 clutch
fidanza flywheel
motor
cp pistons
ki rods
.5mm overbore
fuel
dezod return system
rc 750cc's
depends on how much timing you are running. meth helps alot with that. also the 2.1 manifolds are not equal length. but remember that numbers vary from dyno to dyno. sounds like the right numbers give or take.
sry i added the managment to the list.. yea the tuner is on vaca this week so the shop owner did the tune. I heard he is good tho. he said my turbo could allow any more psi or some crap. I said thats impossible and that my turbo should actually be overkill. He said you should see if its a actual gt turbo and not a knock off.
a true 35r should put you in the 500 range!!! depending on your setup and all but if your running a 35r you should have a setup and tune to back it up and there shouldnt be a problem with hitting 450 on a 35r
