378whp @ 20psi.. does that sound right?
Old 05-19-2010, 01:56 AM
NVMyTc's Avatar
What dyno was this on again?
NVMyTc is offline
Old 05-19-2010, 01:58 AM
BoostedBeastBox's Avatar
oh that would help dyno dynamics
BoostedBeastBox is offline
coryjames's Avatar
i made well over that on the stock block with a gt30 and full 3 inch exhaust at much less psi i run e85 but still 390 on 20 psi something is wrong
coryjames is offline
Old 05-19-2010, 02:02 AM
i wasnt there when it was done. he asked me how much psi i wanted. i said 20 should get me where id like to be. I have this feeling he just said this was on 20 and it really wasnt
Old 05-19-2010, 02:08 AM
crush02342002's Avatar
Originally Posted by BlitzBlueBeast
lol.where did you get yours? i may look into that. i hear they leak after a while.. I am talking about the same thing rite? lol
mine hasnt leaked like i always heard it would...atleast not yet but iv had mine for two years now i think.
crush02342002 is offline
Old 05-19-2010, 02:09 AM
out of curiousity what is the wastegate spring?
RusWolf's Avatar
Do you have boost controller, check what he left the controller on.
And yes like most people stated 378 on 20 psi seems lower then usual.
Look at my set up and look at what i made.
I think my numbers are pretty good and i have not seen anyone else make higher then what i did #16 psi on our cars on 93 pump gas, but i have heard from brett that he thinks i should have made more. I'm not denying i think i could have, but most likely my tuner also tuned with safety in mind and the tune is not as agressive as it can be.
RusWolf is offline
Old 05-19-2010, 02:12 AM
crap i forgot.the minimal psi level is 14 if that helps
Old 05-19-2010, 02:15 AM
06sciontcnda704's Avatar
what this setup i would expect 410whp
06sciontcnda704 is offline
Originally Posted by RusWolf
Do you have boost controller, check what he sat the controller on.
I do, got the aem tru boost. it was raining bad so i didnt want to see what i max out at on the way home and i didnt think of checking it from the gauge untill.. well you just said it. lol Ill make sure to check tomorrow
Old 05-19-2010, 02:19 AM
cessblood's Avatar
It must be the tuner. Who is your tuner? Do know anyone else that had problems with this tuner?
cessblood is offline
Old 05-19-2010, 02:20 AM
By RusWolf
#s do look pretty good. I actually have the stage 2 cams also but they are on my living room floor Ive been trying to sell them but after this i really think i will hold onto them and re-install later on
Old 05-19-2010, 02:24 AM
no not that i know of. The thing i do know is they specialize in subbies/evos and are always crazy busy. They did 1 tc before using a fic. The car has never moved it just sits in their lot for the past year. That should of been the 1st sign.
I was going to fly some1 out to tune that is more familiar with the platform but i had a issue like i said and it went to them and i figured it was already there so eff it
Old 05-19-2010, 02:25 AM
The name of the place is the shop. theshopct.com
Old 05-19-2010, 02:28 AM
something has to be wrong a guy down here has that exact same setup but 900cc ptuning inj and hes making 420whp
Old 05-19-2010, 02:29 AM
^ on how much psi?
Old 05-19-2010, 02:32 AM
there it is
Old 05-19-2010, 02:35 AM
m6ar2cel6oTC's Avatar
Default 378whp @ 20psi.. does that sound right?
Firt of all there is no way In hell that your gt35r is max out not even close. And yes the numbers do seem kind of low but you never know he might have tunes you very very conservative. I made 376whp on 17 psi and I have a 60-1. Which I think the gt35 is a tad bigger. Plus if you do get 3" you will increase those numbers. I made 420whp on 20psi but then again I had meth. I say leave it like that till you raise the boost and then tune again with the actual tuner. Or install the cams get meth and 3" and call it a day and you will for sure break 500whp. That guy is full of ____ telling you your turbo was maxed out. Lol he probably saw you and said ____ I didn't make him enough power. How's the powerband? Did it drop off at the end of redline? If not the. Your turbo is good an the tune is not. Either way brother those are good numbers.
m6ar2cel6oTC is offline
Old 05-19-2010, 02:38 AM
spikes like 21psi tapers off to about 18psi
Old 05-19-2010, 02:39 AM
cburglb34's Avatar
wtf...your maf is backwards...its readin backwards...please tell me ur on a standalone and ur maf isnt being used...cuz if ur maf is being used u have an issue
cburglb34 is offline
Quick Reply: 378whp @ 20psi.. does that sound right?
