378whp @ 20psi.. does that sound right?
Old 05-19-2010, 03:38 AM
  #61
m6ar2cel6oTC's Avatar
Default 378whp @ 20psi.. does that sound right?
Originally Posted by 06sciontcnda704
haha thats funny he said a 35r was maxed out on 380whp thats fresh a ported 16g maxes out at that level
What 16g maxes out there? Link please preferably on a Tc.
m6ar2cel6oTC is offline
  #62
yamaha16bw's Avatar
I had the drift spec back when I first went turbo and it was 2.25 unless they redid it.
yamaha16bw is offline
Old 05-19-2010, 03:39 AM
  #63
yamaha16bw's Avatar
Just dump after the spipe and watch the numbers go way up.
Old 05-19-2010, 03:43 AM
  #64
Team Scionara
skinnayyy's Avatar
doesn't megan advertise it as 2.5 inch... but outside diameter? and the inside diameter is more close to 2.25?
skinnayyy is offline
Old 05-19-2010, 04:10 AM
  #65
brett561tc's Avatar
Originally Posted by BlitzBlueBeast
there it is
yeah that version is not equal length.
brett561tc is offline
Old 05-19-2010, 05:40 AM
  #66
trd07tc's Avatar
what exactly is "maxed out"??
junk the exhaust
its just a dyno you dont have to live by the numbers. real numbers are at the track
trd07tc is offline
Old 05-19-2010, 09:27 AM
  #67
06sciontcnda704's Avatar
i meant a ported 16g with 20g wheel guy with a subie down here is making 360awhp and he thinks it has a little left in it
06sciontcnda704 is offline
Old 05-19-2010, 12:00 PM
  #68
gwopsta's Avatar
exactly why i made this thread. All i know is i put about 15k into this project and 378whp isnt cutting it lol
15k + 378whp = FAIL
i make 330whp @13psi and i have less than 3k in my setup
gwopsta is offline
Old 05-19-2010, 12:54 PM
  #69
ElevationTC's Avatar
Originally Posted by gwopsta
15k + 378whp = FAIL
Were u end up gettin tuned?
OP:
Exh is your first issue. Second, what gas is avialable were you are?
Pump Gas can only go so far. Right around 18+ PSI is were u see massive timming needed to be taken out.
First Post Dyno Sheet.
Sorry to hear your still having issues. Does it feel good while driving? At that hp, You should have NO 3rd gear on the street.
ElevationTC is offline
Old 05-19-2010, 01:15 PM
  #70
Music City Scions
rhythmnsmoke's Avatar
Yeah Big Evo III 16G is rated to 380.
rhythmnsmoke is offline
Old 05-19-2010, 02:07 PM
  #71
Scionetics
KAD
paul_dezod's Avatar
I am curious, maybe he is lacking timing in the setup? What standalone are you running? VVT-i tuned? Ditch the stock cams! Run an open downpipe to rule out exhaust restriction as a possibility.
paul_dezod is offline
Old 05-19-2010, 02:29 PM
  #72
FlintMica2005's Avatar
megan's inner diameter is 2.25" the outter is 2.5". tsudo is a 2.5" exhaust
FlintMica2005 is offline
Old 05-19-2010, 02:52 PM
  #73
Ronin Scion
Ace83's Avatar
how much timing? it shouldnt be the manifold, the exhaust you may free up a bit.. megan has 2.25" section on one or more of the bends.. how is the turbo spool and boost build?
If afrs and timing good, consider doing the VVTi map. thats what im doing next time i get on the dyno
Ace83 is offline
Old 05-19-2010, 03:09 PM
  #74
BoostedBeastBox's Avatar
Ok guys, I will respond and post dyno graph when I get home from work later. I can't get on the site from my job and there's no way I'm trying to use my crackberry to get on more then I have too. In the mean time ill take a ride @ lunch and see where the boost is @, ect.
BoostedBeastBox is offline
Old 05-19-2010, 03:11 PM
  #75
What I don't understand is the inner diameter is 2.25 and the outside 2.5? What the piping is .25"? Anyways it has to be timing and the exhaust restriction. Do what Bret said to do a cut out or jump to 3"
Old 05-19-2010, 03:14 PM
  #76
yep. they advertise it as a 2.5" but in all reality its not. from outter to outter it is a 2.5" but when you measure the inner its 2.25", which is false advertisement from megan.
tsudo is in fact 2.5" inner diameter.
  #77
Ronin Scion
Ace83's Avatar
^^ megan advertise its a 2.5, but ive heard it confirmed before it has sections with 2.25".. the pipe thickness cant be 0.25" though lol, is just sections of it that are 2.25
so yeah do as what mentioned, high boost on small exhaust is not good.. run using just the dp and see what happens
Ace83 is offline
Old 05-19-2010, 03:21 PM
  #78
trd07tc's Avatar
15k + 378whp = FAIL
This post is a FAIL
trd07tc is offline
Old 05-19-2010, 04:26 PM
  #79
gwopsta's Avatar
Post
OP:
i used the base map crush sent me a while back its tuned up to 14psi, we just made some minor adjustments and its still running rich w/ conservative timing
@trd how is my post fail?? 15k and 387whp is horrible
gwopsta is offline
Old 05-19-2010, 10:11 PM
  #80
trd07tc's Avatar
the road between low 300 and high 300 on these cars is an expensive one.
I would hate to see you cross that bridge with a tight budget in mind.
trd07tc is offline
Quick Reply: 378whp @ 20psi.. does that sound right?
