The 500whp Build (hopefully!)
Old 04-09-2008, 06:46 AM
  #41
Ronin Scion
Ace83's Avatar
sure will, he might lag fro about 5k but he might be revving more 2-3K more too
Ace83 is offline
Old 04-09-2008, 07:08 AM
  #42
Mightygnu's Avatar
8k is in his future.
so is the curse!
Mightygnu is offline
Old 04-09-2008, 07:22 AM
  #43
bkuhl's Avatar
so is the curse!
yeah, but i'm hoping for the best. I'm so </3 after what Paul went through...makes me cry.
bkuhl is offline
Old 04-09-2008, 12:42 PM
  #44
_Reaper_'s Avatar
Screw the curse this is getting done and done right! but just remember good things take time... Im not just gonna slap this all together asap I want to make sure everything is perfect before I get ahead of myself just to see the #'s (track or otherwise)
_Reaper_ is offline
Old 04-10-2008, 01:40 AM
  #45
ScionCREW's Avatar
Good luck on your project Reaper. Your in good hands there. Let us know if we can help in any way.
Arthur
ScionCREW is offline
Old 04-10-2008, 03:13 AM
  #46
sciontcnj's Avatar
go Reaper!...good luck with this...and for all the haters about the "its only a 2.4L" thing...look at the rsx/si crew that has a k20 block running high hp/trq numbers as well.....
much respect coming from a 8cyl to a 4cyl...have fun saving money on gas....youll save enough to help on your build..lol j/k
sciontcnj is offline
Old 04-10-2008, 03:19 AM
  #47
TCFROEZEL's Avatar
maybe you refer to me as hater.
i just tell the truth man.
sometimes truth hurtsz people.
i ain't seeing the 2.4 Liter spoolin the GT40.
i owe a V6 turbo with head work and all i could spool the GT37 and now the GT40.
but i have a lot more discplacement.
anyway good luck reaper.
Prove me wrong!
TCFROEZEL is offline
Old 04-10-2008, 03:33 AM
  #48
davedavetC's Avatar
if you aint seein the 2.4 L spoolin the GT40 your eyes must be closed.
davedavetC is offline
Old 04-10-2008, 04:14 AM
  #49
TCFROEZEL's Avatar
Your's does spool the GT40 ?
send me video.
i'd be glad to take a look.
spool eficiently i doubth about it.
maybe spoolin it at 6000 RPM is not eficiently spoolin for me.an the rev cut out at 7000 RPM.
Old 04-10-2008, 04:16 AM
  #50
nebster's Avatar
http://www.nittotire.com/#index%2Emi...e%2Escion%5Ftc
nebster is offline
Old 04-10-2008, 04:34 AM
  #51
TurboToyotas's Avatar
Displacment doesn't mean as much as people thing it does. Its all about the velocity of the air moving out of the motor....
Plus I guess you dont pay much attention to all the 1.8 and 2.0L Honda motors running GT4294's and GT4202's.
+ you also have to take in consideration the manifold design....twin scroll turbo, when used with a twin scroll manifold has a tremendous effect when using a large sized turbo on a small displacement motor.
Regards-
Todd
TurboToyotas is offline
Old 04-10-2008, 04:36 AM
  #52
TCFROEZEL's Avatar
T04Z is a Gt40 ?since when ?
Old 04-10-2008, 04:40 AM
  #53
TCFROEZEL's Avatar
Regards-
Todd
TOdd those honda's have lot's of revs,
and they have cams 4 sure.
we don't have that much rev on the motor.
i am not rryin bash on anyone in this thread, but eficiently spoolin the GT40 and still be Street .i have big doubths.
Old 04-10-2008, 04:46 AM
  #54
nebster's Avatar
lets look at the specs
t04z
Turbine
-Wheel: 74.2mm w/ 76 trim
-Divided Housing A/R: .70, .84, 1.00, 1.15, 1.32, 1.59
-Undivided Housing A/R: .61 and .70
-Maps
Compressor
-Wheel: 84.0mm exd./66.7mm ind w/ 63 trim
-Housing: 0.70 A/R
-Maps
gt40
Turbine
-Wheel: 77mm w/ 78trim
-Housing: .85, .95, 1.06, or 1.19 A/R
-Maps: Not Available
Compressor
-Wheel: 88mm w/ 52 trim
-Housing: .58 ar
-Maps
so whats the big diff here.... on i'm sorry its 1mm trim bigger. i really don't think that'll be a problem
nebster is offline
Old 04-10-2008, 04:59 AM
  #55
NurSpec's Avatar
Still man tit's a 2.4 Liter.
with head work doesn't mean he can spool a GT40.
According to Garrett The GT40 series only needs 2.0-6.0* liters of displacement. It will take some time to reach full boost, but once there he will be happy with the results.
*http://www.turbobygarrett.com/turbob...2_452232_5.htm
A turbo will spool at idle. Spool meaning spin.
NurSpec is offline
Old 04-10-2008, 05:01 AM
  #56
NurSpec's Avatar
There is no such thing as a curse. Just dont go for a power maxed out dyno run 2 weeks after the build.
Take your time and slowly build up the boost.
NurSpec is offline
Old 04-10-2008, 05:11 AM
  #57
TCFROEZEL's Avatar
t04z
Turbine
-Maps
Compressor
-Housing: 0.70 A/R
-Maps
gt40
Turbine
Compressor
-Housing: .58 ar
-Maps
WOW the way you are talking i gues you know a lot.
1 MM trim bigger has no difference.
Tsss.
Old 04-10-2008, 05:12 AM
  #58
TCFROEZEL's Avatar
In this game i know form experience not always play by the rulez,
make your own rulez.
and for sure don't trust manufacturers specs.
Old 04-10-2008, 05:27 AM
  #59
HighMPGTesting's Avatar
I have never done anything with turbos before, and I don't have any engineering experience with them. However, I do have a question:
Would it be possible to build a dual turbo motor? What are the drawbacks of having one smaller and one larger turbo, one for lower RPM use, and a second one for higher RPM use? Also, can you use the exhaust gasses from the smaller turbo (from two cylinders) and send it over to a second, larger turbo (using it and the other two cylinders)?
I don't know the dynamics of what is involved. It just seems to me that if this type of setup is in any way feasible, it might give you the boost and performance that you are looking for. But again, I am ignorant of the engineering aspects or the feasibility of this type of setup.
If I get flamed, I probably deserve it , but I had to ask...
Thank you for your patience...
HighMPGTesting is offline
Old 04-10-2008, 05:43 AM
  #60
1A4
1A4's Avatar
cant wait to see the finished product!!
1A4 is offline
Quick Reply: The 500whp Build (hopefully!)
