550CC Injector Max Boost - Compressor A/R.50 - Turbine A/R.63
With a turbo with a Compressor A/R.57 - Turbine A/R.63 and 550cc injectors, what is the maximum amount of boost you can run? Any insight would help. Thanks
I think you mean a .60 AR with a 57trim compressor wheel?
Regardless of the turbo, 550cc injectors will probably max out around 325-350whp (assuming around 80% duty cycle and 43.5psi baseline fuel pressure.)
Anyone else with hard evidence please chime in.
your absolutely correct. You could get close to those #'s but with the stock returnless Id say safely the lower end of your scale. 300-325. return system go for the upper end, but duty cycles will be pretty high
Yes you can.. you'll be up to about 450-500whp at 900cc but it's recommended that you go for a return style setup.
SloTC1
08-16-2018 02:45 PM
crimson_sinn
09-25-2015 09:41 PM
kslim619
09-18-2015 06:54 PM
