550cc Injectors.....
Old 05-15-2008 | 07:53 PM
leadfoot's Avatar
United Imports
Default 550cc Injectors.....
Getting ready to install turbo in the tC.... bought 550cc injectors.... DO I NEED TO UPGRADE the FUEL PUMP has any buddy done it yet please let me know...... or are you all still running stock pump..... please let me know want to to do this right....
Old 05-15-2008 | 07:59 PM
tC_2NeR's Avatar
No your just fine with your stock pump.
Youre good to go
Old 05-15-2008 | 08:00 PM
Rydrdg's Avatar
I am running pnp 550 cc with my greddy turbo kit and it is stock fuel pump
Old 05-15-2008 | 08:02 PM
leadfoot's Avatar
United Imports
Default Well"
Well" your cars are all still running alright huh.... weird i was told to change it.....since im running bigger injectors ans such but im using the AEM FIC>>> to control it....
Old 05-15-2008 | 08:03 PM
Crippie's Avatar
1UP Crew
ive heard the stock fuel pump is good till about 400+hp... im workin on 300 with stock fp
Old 05-15-2008 | 08:05 PM
leadfoot's Avatar
United Imports
Well that good to hear are you all enjoying the fun of a powerful car.... I live in WA State and have seen two turbo'ed tc's and they both look like crap.... but i cant wait till this is all done what exhaust are you running i plan on running 3" Ptuning exhaust...
Old 05-15-2008 | 08:21 PM
Crippie's Avatar
1UP Crew
i opted for the 2.5 tsudo N1 spipe back system with a 2.5 creative compacts spipe. figure if i ever up my setup, ill go to 3.0 then, but by that time, ill have to swap out turbine, mani, buy an external wg, then up the piping to 3
Old 05-15-2008 | 08:22 PM
paul_dezod's Avatar
Scionetics
KAD
What type of power are you looking to run regularly? If less than 300whp, you will be fine with the stock pump. If more than that DD, I would recommend the pump.
Old 05-15-2008 | 11:34 PM
Joe_Dezod's Avatar
Word. The pump keeps up decently up to about 300whp, but then the pressure starts dropping off significantly.
Having a stronger pump with a good FPR will keep the fuel atomizing well, which prevents detionation. That allows you to make more power with a longer lasting engine. This isn't necessary, but it's always a nice upgrade.
Old 05-15-2008 | 11:38 PM
Ace83's Avatar
Ronin Scion
so up to 300 whp huh before i upgrade? i thought it was more, but i'll just get one if i hit 300s just to be on a safe side..
Old 05-15-2008 | 11:47 PM
Joe_Dezod's Avatar
You definitely don't need it. I made over 300whp for a long time and never ended up upgrading.
We suggest it because it's better for the car. I'm not sure how much power you can make with just a pump upgrade, but having less detonation is always a plus.
The new Mazdaspeed cars and the 335i BMWs run 1600psi for fuel pressure! That's how they get to turbo their cars while still running hgih compression. They have direct injection, so don't expect to come anywhere near those pressure levels for our fuel setup.
Old 05-15-2008 | 11:58 PM
Ace83's Avatar
Ronin Scion
less detonation, does it mean that it will richen up you tune after the upgrade or it will just improve/maintain a consistent fuel pressure thus preventing fluctuation brought by the bigger injectors and more fuel demand?
Old 05-22-2008 | 07:00 PM
enjoithis's Avatar
If you upgrade the fuel pump do you need to adjust the entire map?
Old 05-22-2008 | 07:13 PM
paul_dezod's Avatar
Scionetics
KAD
Yes. It will richen the entire map across the board.
Old 05-22-2008 | 07:15 PM
enjoithis's Avatar
evenly? run a % decrease across whole map?
Old 05-22-2008 | 07:16 PM
paul_dezod's Avatar
Scionetics
KAD
Not really.
Old 05-22-2008 | 07:19 PM
enjoithis's Avatar
haha worth a shot :/ well looks like im buying a fuel pump then doing a retune!
Old 05-22-2008 | 07:42 PM
tcdaily's Avatar
well technically anything bigger than stock you would need a different fuel pump, because it was designed to work with stock injectors, although running 550 and 440cc with stock fuel pump is fine, i have a walbro one sitting at home just in case though..
Solowcal_tc1
14
02-27-2024 06:23 PM
Greg S
07-21-2016 07:28 PM
vi3tb0i09
09-23-2015 08:32 PM
bbsciontc
06-12-2015 03:22 AM
LucidBD
07-22-2007 01:05 AM
Quick Reply: 550cc Injectors.....
