61mm tc versus 2004 R1
Old 09-14-2009, 06:38 PM
  #121
coryjames's Avatar
will you be making a ems for the xb2
coryjames is offline
Old 09-14-2009, 06:48 PM
  #122
tofast4u's Avatar
Originally Posted by B_Real45
That's interesting - where do you have your EGT sensor mounted? Mine is in the manifold about 1.5" away from port #3 - and I see 1400*F while cruising at 85mph.. 14.2-14.7 AFR, 7-range iridiums gapped .030", 93 octane.
I have it mounted beside the turbine housing of the turbo, I also have a bung on cyl2, 4 on the bottom, I have had it in different spots, EGT readings were exactly the same from where I had them seperate and beside the turbine housing, If they varied, it was no more than 20 degrees.
I have my cruising afr set to 13.5-13.6 thats probably why my egt's are lower.
what is your EGT's under boost?
tofast4u is offline
Old 09-14-2009, 06:52 PM
  #123
B_Real45's Avatar
EGT under boost will be high - usually around 1600*F WOT, 11.5 AFR, 11psi, 5th Gear, 90*F weather high humidity.
B_Real45 is offline
Old 09-14-2009, 07:08 PM
  #124
tofast4u's Avatar
HMM.. your heatrange should be fine on your plugs, The most I have ever spiked to on the aem is 1300 WOT. thats with 15 degrees of timing .. q16 though
1600 is still not bad, my supras egts usually go 1650-1750, 24 degrees of timing, but 36-40 psi
tofast4u is offline
Old 09-14-2009, 07:28 PM
  #125
Music City Scions
rhythmnsmoke's Avatar
Originally Posted by tofast4u
thanks for all the comments guys.. this forum and supra forums I like because its not so drama filled with someone always trying to talk smack
Well, I wouldn't go that far....hehehe...
You can get a .58 in a t3, I have access to anything turbo related..lol.. Mine was t3, and my .63 is t3. There is a difference in a t3 t4 sure, but for her setup, and daily driving and spool charecteristics, I dont really need one yet. I want to make some good power on this turbo and then be done..lol.. take it to the drag strip some, thats about it, Ive gotta get my supra finished, I have been killing myself on this car for 2 months just doing things to it..
BTW Dyno vid is coming
Where did you get your turbo from? And have you dynoed on Pump gas?
rhythmnsmoke is offline
Old 09-14-2009, 07:33 PM
  #126
Scionetics
KAD
paul_dezod's Avatar
I think Justin is a Comp Turbo dealer (so are we).
paul_dezod is offline
Old 09-14-2009, 07:42 PM
  #127
Music City Scions
So, the only thing left on the kit that's Dezod is what? Manifold, and intercooler pipes and piping?
Old 09-14-2009, 07:47 PM
  #128
Scionetics
KAD
paul_dezod's Avatar
From what I have seen is our manifold, wastgate, lines, intercooler, piping and AEM EMS. The only thing he replaced out of the kit (to my knowledge) would be the turbocharger. It's a little large for us to put something like that in a kit unless it's custom by request.
Refer to these videos:
https://www.scionlife.com/forums/sho...d.php?t=171349
Old 09-14-2009, 07:49 PM
  #129
Ronin Scion
Ace83's Avatar
what was the EGTs again? 1300? thats a cool EGT, im sure more power could made with it fine tuned.. 11.7 AFR for a race gas is damn conservative yet power is good. Im curious how was intake charge temp though w/ the spray, i know the fan was pretty small and that spray should fix the heat soak
Ace83 is offline
Old 09-14-2009, 08:21 PM
  #130
Music City Scions
I've already posted there...lol. Kinda at the same time.
Old 09-14-2009, 10:48 PM
  #131
tofast4u's Avatar
its usually that at the highest crusing, usually 1150-1250, and then WOT falls to 1210-1220. its very conservative for that gas.
Im gonna stick some VP import in it and run much higher timing.
My actual intake temps vary with the hood open they were 120 or so, and 115-150 with it closed in 90 degree weather.
tofast4u is offline
Old 09-14-2009, 11:06 PM
  #132
tofast4u's Avatar
Paul at Dezod can help you at at a good deal. Its worth every penny
tofast4u is offline
Old 09-14-2009, 11:59 PM
  #133
Music City Scions
I've been boosted for 3+ years. Sold the kit because I'm getting the PTuning kit. Dezod kit is not efficient enough for what I need to do (Time Attack).
Old 09-15-2009, 01:18 AM
  #134
tofast4u's Avatar
[QUOTE=rhythmnsmoke;3297875]I've been boosted for 3+ years. Sold the kit because I'm getting the PTuning kit. Dezod kit is not efficient enough for what I need to do (Time Attack).[/QUOTE
Paul can get you a 3" vband turbine housing. It would work
tofast4u is offline
Old 09-15-2009, 02:23 AM
  #135
Music City Scions
PTuing already provides a 3inch vBand turbine housing with the GT3076r. Their kit is designed and more importantly...engineered to bolt up directly to their 3 inch turbo back exhaust system. When I sold my last kit, I was using a ZPI Stage 1 originally. Then I upgraded the kit to a 20G, redid the oil setup and redid the piping. ZPI obviously used log manifold, and I ran a 2.5 inch ZPI exhaust setup that was custom to an Aero Turbine muffler out back (no cat, no res).
http://www.youtube.com/watch?v=Y7PzQ28LaXE
After riding in PTuning's Time Attack tC, and seeing their EL manifold, GT3076r combo with 3 inch exhaust...it spooled like my 20G did, but carries the punch well beyond that. It's race proven, so that's my route now. Sold that kit, just waiting to get the rest of things taken care up to finish my Time Attack build.
https://www.scionlife.com/forums/viewtopic.php?t=252913
kb1sxv
10-21-2015 05:00 PM
EVILDAVE
09-15-2015 06:54 AM
rhino8648
09-06-2015 04:04 AM
pjl52
08-13-2015 02:38 PM
Quick Reply: 61mm tc versus 2004 R1
