9.5 pulley and belt problem
Old 11-30-2007 | 12:53 AM
GammaTNT's Avatar
Default 9.5 pulley and belt problem
my K070890 belt got shredded.
i install the oem belt back on, (Jegs's gates belt is on back order)
I run the car for 10 minutes. The the belt seem to be moved out a little on the idle pulley.
My question is "Did I install the pulley too far in?"
Old 11-30-2007 | 03:42 AM
imsonofagun's Avatar
I've run in to a similar situation, but my idler pulley and the nut for the alternator pulley are covered in rust. My belt is squealing and is starting to shred.
I ordered a new belt, idler pulley set with hardware, and have the NST alternator and water pump pullies. That should take care of my problem.
There are shims for the idler pullies that might need adjustment to get the belt aligned properly. If you are still within the warranty period, you might be able to get the dealership to fix it. I decided I don't want the hassle of dealing with the dealership, and wanted to upgrade a couple pullies while fixing the problem.
Old 11-30-2007 | 04:03 AM
GammaTNT's Avatar
i don't think the dealership will like my NST pulley, i can't go to them.
Old 11-30-2007 | 04:23 AM
JPsTc's Avatar
1UP Crew
How many people have had this problem? Im gona be swapping pulley's soon.....
Old 11-30-2007 | 09:14 AM
Ex_sPEC's Avatar
Default Re: 9.5 pulley and belt problem
how did the belt got shredded ? ? ? ?
Old 11-30-2007 | 05:19 PM
GammaTNT's Avatar
the belt move out away from the engine. It move 2 grove away on the sc pulley.
Old 12-01-2007 | 12:34 AM
Ex_sPEC's Avatar
so would u still recommed the K070890 belt ? ? ?
Old 12-01-2007 | 05:12 AM
GammaTNT's Avatar
i ordered shorter belt, K070886, it is half inch shorter than K070890. I should get it in 7 days from Jegs.com
i will let u know after i install it.
Old 12-01-2007 | 07:14 AM
Ex_sPEC's Avatar
so with the K070890 gates belt ? ? ? is that a common problem with it shredding ? ? ?
Old 12-01-2007 | 04:34 PM
GammaTNT's Avatar
no, i seem to be the only one.
Old 12-01-2007 | 10:36 PM
I ran across a similar problem, and has been that way for a couple weeks. Today my squealing (and belt shredding) went away because the belt popped off. I have a new belt, alternator pulley, and water pump pulley ready to get put on. Still waiting on the idler pulley and hardware kit (taking forever) to get here. The hardware kit should come with shims to help align the belt, so I shouldn't have this problem anymore.
Old 12-02-2007 | 05:15 AM
GammaTNT's Avatar
my OEM belt slip off. I am waiting for Jegs to ship me the new belt.
Old 12-04-2007 | 01:22 AM
Ex_sPEC's Avatar
is that with the gates belt ? ? ?
Old 12-04-2007 | 01:51 AM
Finally got the idler pulley and hardware kit, but it's only one pulley, and the hardware kit is only a bolt. What sucks is the bolt cost more than the pulley. I hope to get everything put on this week.
Old 12-04-2007 | 01:53 AM
Yes, it was the gates belt, but I don't think it's a problem with the belt. My problem is most likely with the rusted pullies.
Old 12-13-2007 | 12:21 PM
GammaTNT's Avatar
the k070886 belk is way too short. i am getting K070890 from NST again. i think i need to align my pulley
Old 12-14-2007 | 01:32 AM
kikcaffine's Avatar
Mine did just the same thing yesterday..... Lame got a new belt and moving on
Old 12-14-2007 | 01:36 AM
Garage1217's Avatar
The SC pulley is lined up just fine from your pics, you miss-aligned the belt on the rear waterpump pulley which nuked your belt. Quite clear in the photo. Install error.
Old 12-14-2007 | 04:47 AM
GammaTNT's Avatar
Thanks for the info. Got to double check my install next time.
Old 12-14-2007 | 05:02 AM
Garage1217's Avatar
All good man, We have all done little things like that when we play with cars long enough. No biggie!
