9.5 pulley install
Old 05-25-2012 | 10:26 PM
Jbarker1983's Avatar
Obviously but it's a pretty big difference wouldn't think it would make that much
Old 05-25-2012 | 10:44 PM
gompka's Avatar
Remember that our cars are not intercooled
Sent from |Android|
Old 05-25-2012 | 10:47 PM
I know that just wondering if there is anything else that could cause this I may have a exhaust leak where the header bolts to the down pipe I'm missing a spring bolt but the donut gasket is there and it's not loose so idk. I have a cheap eBay filter on my CAI thinking about getting a aem dry flow tomorrow not sure how much better it is
Old 05-25-2012 | 10:50 PM
gompka's Avatar
With an exhaust leak or bad air filter, the power would be consistently lower, wouldn't material what time of day it is. It's a big difference, my tc always rank best in the fall.
Sent from |Android|
Old 05-25-2012 | 10:56 PM
Lol it's only about 70-75 here not looking for summer then dam car will be even slower lol I got the 9.5 pound pulley on there to I have the 12 lb but need the supporting stuff for that
Old 05-28-2012 | 07:36 AM
TurboMonkey36's Avatar
I just replied to someone else's thread on belt slipping issues, but after trial and error I found out that it was the light weight crank pulley for me. If you decide to put your stock one back on, lmk how it goes. Mine slipped more as I went into higher gears as well. It didn't slip with oem nor 9.5 lbs pulley and oem crank, but it did slip with oem and 9.5 pulley and light weight crank. I used boost gauge to verify and rsx-s lol.
Old 05-28-2012 | 04:11 PM
That was my other thread lol. My crank pulley isn't the problem it's definatly belt length cuz the OBX pulley is alot smaller than oem so using the same belt works but when I get on it screeches like a **** normal driving is fine
Old 05-28-2012 | 11:13 PM
Well lol! Belt length shouldn't be too much of a problem because our cars are fitted with a tensioner. Yes go smaller, but it shouldn't screech at all. You know my recommendation lol. The more force (wot) and time of that force (higher gear), the more susceptible the belt is to slipping.
Old 05-29-2012 | 10:30 PM
Yeh got to get a 880 belt Rght now got a 885 if it's slipping at wot then I'm probably loosing boost Rght ?
Old 05-30-2012 | 08:21 AM
Yes exactly. A boost gauge would tell you how bad it is.
Old 06-01-2012 | 05:18 AM
Got a K070880 belt the fit was pretty tight I hope it's not to tight
Old 06-01-2012 | 06:03 AM
What model supercharger do you have? By K070880 it seems like you may have the 05-06 model year supercharger? Does it have one or to idler pulleys at the top?
Old 06-01-2012 | 06:06 AM
2005-06 s/c 9.5 pulley and the smaller alternator pulley by OBX a 882 might fit better but I had a rough day with this ____ my jack collappsed and fuxked up my rocker panel so this belt ____ is a pain lol
Old 06-01-2012 | 06:14 AM
I still have some belts left over doing what you were trying to do lol.
Old 06-01-2012 | 06:16 AM
The tensioer is close to max I'll switch it out soon for the 882 I still got the nst 12lb pulley to install so I'll need another belt then lol
Old 06-01-2012 | 06:28 AM
Really? I don't remember mine being that close. Well, I'll take your word for it. Oh and be careful, use jack stands when working under a vehicle, that car doesn't have feelings for you, it just obeys the laws of physics. Sorry to hear about your rocker panel.
SuBSiN
03-13-2015 05:02 AM
Frustratez
02-26-2015 05:03 PM
NonStopTuning
01-20-2015 06:20 AM
TheTripleC
01-04-2015 07:46 PM
TheRedBox
31
12-02-2003 05:53 PM
