ACT Users
theres a rod behind the clutch,use a 12mm wrench to crack the nut loose,then with two fingers,very tight spot and pita....just turn the rod clockwise to bring the pedal higher,like 3-4 full turns depending on where you want the clutch to engage...then just lock the nut,but make sure you hold the rod while tightening the nut,if not,the rod will turn with it and you just wasted your time turning it,which you dont want..
Jayrdee
10-15-2015 03:38 PM
gyrotech
Scion tC 2G Aero & Exterior
10-04-2015 11:03 PM
Darrenohooligan
09-26-2015 07:21 AM
