Adjusting the Pedal Stop?
Hey guys im having Pete or aka TC Pete come to adjust my clutch pedal 2morrow but i also need the pedal stop adjusted a tad big as the spline covering that the throw out bearing goes on chipped badly near the end so i need to make it so the clutch doesnt get pushed to the end which is solved by making it so the pedal isnt pushed all the way or adjusting the pedal stop, so does anybody know to how to do this?
on your clutch master cylinder there is a rod that pushes in and out of it.....it has a 12mm nut on it that you loosen to adjust this....i had to do this 2 days ago actually cause my clutch wasnt disengaging all the way.....the easiest way i found to do it was to actually take the master cylinder out....reason being is because i have a bad back and couldnt lay under my dash for more than 30 seconds........the rod attaches to your clutch pedal with a pin...thats the rod you want to adjust
