The AEM ECU and what it can do
Old 05-18-2006 | 06:10 PM
  #41
Parts_Pimp's Avatar
It should work with the auto too..
Old 05-18-2006 | 08:39 PM
  #42
retrodrive's Avatar
AEM and auto is pain. You loose lockup when you go AEM on auto and to people who actually have such setup (me on the car on my profile) it is a big deal and a pain in the ___. It will work but you need a manual lockup seitch which still sucks.
Old 05-19-2006 | 03:03 AM
  #43
05-RS1's Avatar
Originally Posted by retrodrive
AEM and auto is pain. You loose lockup when you go AEM on auto and to people who actually have such setup (me on the car on my profile) it is a big deal and a pain in the butt. It will work but you need a manual lockup seitch which still sucks.
i hooked up a standalone Hondata Kpro system to an automatic RSX. i'm the very first and only one to do such feat. i had to make it work correctly with the automatic.
there are many factors that activate the lockup. something as simple as the ECT wire can keep lockup from engaging. i see ur pushing 600+, which means u're not using the stock MAP/MAF sensor. the auto tranny does not/will not recognize another type of airflow sensor, therefore can throw it off.
i've encountered this problem on my RSX, i had to wire the stock MAP sensor wire DIRECTLY to the auto ecu. but i dont really know your setup so i cant really help u.
there is a possiblity the wiring on the harness you're using is not complete. ATF temp, ECT temp, MAP/MAF, etc. Many things contribute.
if i had the helms for the tC, and the AEM EMS, i can try to make a harness that will allow the EMS to plug n play. i can even bypass the drive-by-wire system on the TSX to run the RSX Hondata KPRO ecu.
Old 05-25-2006 | 03:43 AM
  #44
Moto-C's Avatar
yea with the EMS it will allow alot more out of the motor. Isn't someone making a harness for this as AEM wont be ready till the later part of the year with their plug-n-play?????
Old 05-25-2006 | 04:06 AM
  #45
zer0's Avatar
Toyomoto I believe.
Old 05-25-2006 | 04:14 AM
  #46
paul_dezod's Avatar
Scionetics
KAD
Doubt it will. Most of the AEM apps are 5 speed only. A standalone tranny controller will probably be needed to do all of the tranny shift points and such. We are VERY close to having one working for the tC
Old 05-25-2006 | 04:15 AM
  #47
paul_dezod's Avatar
Scionetics
KAD
Originally Posted by zer0
Toyomoto I believe.
Correct.
Old 05-25-2006 | 11:07 PM
  #48
Moto-C's Avatar
well is there any one using it with some good feedback or #'s to show
Old 05-29-2006 | 06:37 AM
  #49
05-RS1's Avatar
its possible to "piggyback" the stock auto ecu. the main thing is to supply the auto ecu the sensors/wires it needs to run the auto tranny. i've done it before on auto rsx's, even my own.
SloTC1
08-16-2018 03:45 PM
deademon
03-31-2016 10:25 PM
vi3tb0i09
09-23-2015 09:32 PM
Quick Reply: The AEM ECU and what it can do
