AEM F/IC hiccups under boost
Old 05-18-2008, 02:08 PM
enjoithis's Avatar
Default AEM F/IC hiccups under boost
I got the Dezod S1 kit with AEM F/IC - i went to RIPP mods in staten island for a tune yesterday and had Perry tuning it. The AEM keeps throwing crank shaft sensor codes and makes the engine "hiccup" under boost. Perry got it so that it doesnt happen too much but it still does it at higer RMP. Also with 550cc injectors under 8.5psi the richest he could get it could get under boost is around 12 afr.
Any suggestions?
enjoithis is offline
Old 05-18-2008, 02:42 PM
08superwhite's Avatar
idk about the hiccup, but i thought you should tune for around 12.5 afr under boost. am i wrong on this?
08superwhite is offline
Old 05-18-2008, 02:50 PM
enjoithis's Avatar
I have heard anywhere from 10.5 to 12, but richer being safer for a daily driver
Old 05-18-2008, 07:22 PM
Rydrdg's Avatar
just give it some water it will help with the hic ups!!!
Rydrdg is offline
Old 05-18-2008, 07:44 PM
enjoithis's Avatar
yea... thats what they suggested.... but id rather have it running right THEN give it some water!
Old 05-19-2008, 07:12 AM
stockturbo15's Avatar
the tC ECU crank sensor doesnt liked to be touched.
This is one of the differences between the emanage and f/ic. this is the way the f/ic alters timing
stockturbo15 is offline
Old 05-19-2008, 01:58 PM
Scionetics
KAD
paul_dezod's Avatar
What does it do EXACTLY in this "hiccup"
paul_dezod is offline
Old 05-19-2008, 02:06 PM
enjoithis's Avatar
Its like it misfires / detonates. Say your on it - full throttle and pulling hard, it feels like im hittin the breaks for a second. When this happens the CEL comes on throwing a crank shaft position sensor code.
Last night i figured out that this almost ONLY happens under WOT. The timing on my map maxes at a -24 like any other map for the tC, so i dont think its too retarded.
Which wire in the PnP Harness is the wire for the uego input for data logging?
- It also did this with every map that i have tried on it.
Im also running NGK 1 step colder plugs with a 32 gap
F/IC is running version 3
Old 05-19-2008, 02:54 PM
Scionetics
KAD
paul_dezod's Avatar
So wait.............You have -24 degrees of timing?
Old 05-19-2008, 02:57 PM
enjoithis's Avatar
Yea, Same as the Dezod base map, and the "C" map.
Old 05-19-2008, 04:38 PM
Scionetics
KAD
paul_dezod's Avatar
We did NOT set that as the timing required by any means. We left it as a safe buffer your tuner should ween back timing until peak TQ starts to level off then retard a few degrees.
Old 05-19-2008, 04:43 PM
enjoithis's Avatar
so i paid $400 for a half ___ tune?
So what should timing be at? Im guessing at lower RPM a little less than at high RPM since boost only increases at about 3500 rpms. Ill set timing to -19 @ redline, slowly increasing from -16 at 0 rpms (this is under 40 load)
So really i should try ^ my tune see if i get the same problem?
Old 05-19-2008, 04:59 PM
Scionetics
KAD
paul_dezod's Avatar
so i paid $400 for a half butt tune?
Timing @ WOT on the stock PCMs with an OBD2 scanner was verified between 16-22 degrees of full advance. If your values of -16 and -24 are at moderate loads, you guys are sub-par for timing, which leads to power loss and poor fuel economy.
Old 05-19-2008, 05:40 PM
cessblood's Avatar
Half ___ tune. freaking suck. I seen and heard a lot of people getting half ___ tunes lately.
cessblood is offline
Old 05-20-2008, 05:15 AM
enjoithis's Avatar
Did a street tune, now its running at the right AFR's - still hiccups randomly, but only under WOT.
Old 05-20-2008, 05:50 AM
aen
aen's Avatar
i have the same issue.
i need a GOOD tuner.
aen is offline
Old 05-22-2008, 05:51 AM
enjoithis's Avatar
Street tuned and still doing it? Any ideas?
Old 05-22-2008, 04:19 PM
enjoithis's Avatar
So - i found out you can change the intervals on the sides of the tuning software. That makes things easier. The tuner at Ripp must have change the intervals so when i looked at it on my laptop everything looked off. Ill be testing that theory later on today.
Old 05-22-2008, 04:59 PM
aen
aen's Avatar
i thought if you change it on a map it transfers over to the other map even if it's on a different computer
if not that makes things a bit more complicated.
aen is offline
Old 05-22-2008, 05:09 PM
enjoithis's Avatar
I would have expected the same! for whatever reason looking at the map they tuned for me it looks like spark is retared -22 @ 30 PSIA, and only -3 @ 24 PSIA. Plus my fule map has litteraly no gas @ 24PSI
Quick Reply: AEM F/IC hiccups under boost
