Aftermarket header with SC heatshield
I'm looking into getting a header and want to use the TRD heat shield with it. Did some searching and came up with this:https://www.scionlife.com/forums/sho...15&postcount=4
Has anybody done this? My main concern is getting a header with piping that fits under the shield and possibly has the same O2 bung location. I work at a metal shop so I have full access to welders and custom fabricating mounting tabs for the shield to attach to.
Trying to get something with least amount of modification. At the very least I need the runners to fit inside the shield, the O2 bung can be plugged and relocated. I've made drawing file where I can compare photos over the stock header, but that never works 100%.
I finally got around to doing this. This is just a mock-up, but everything fits. I taped weld tabs to the header so that I can bring it in to work to tack them in place. Also, I had to "modify" the shield by pulling some of the curve out near the alternator.
TheTripleC
01-04-2015 06:46 PM
kdanie
12-23-2003 05:18 PM
