Alcohol/Methanol/Water Injection Q&A...
Originally Posted by BionicJuic3
Once installing the Water/Meth Injection System would it begin working immediately or would I need to do some sort of tuning prior to it being able to function at it's full capacity?
Originally Posted by krdshrk
To get any benefit from water/meth you need to get tuned. With water/meth you can push the timing and make a lot more power.
Originally Posted by UltimateCC
any tune will work as long as it can adjust the afrs and if you want to really benefit from it also adjust the timing...
Originally Posted by jsa3mm
Can you spray water/meth in a N/A motor? Is this specific for F.I. motors?
Originally Posted by VitViper
Another question... I'm converting my ZX2 to blow thru... inject into the charge pipe after the MAF or before it?
the dyes they use and they are never as pure as buying pure meth and distilled water...im not saying not to run the washer fluid its just that its cheaper to buy meth and mix your own...
Originally Posted by Kumitsu
can we get some pictures of these kits installed on turbocharged or supercharged tC's ?
there is nothing really to see - look at my profile and the one pic shows the little black box on the right side
Honestly, all you need is Washer fluid (Which is basically water/30% meth) and a couple bottles of ISO HEET Fuel line antifreeze stuff (mostly meth). 1 bottle of the ISO HEET per gallon of washer fluid will get you about a 50/50 mix.
but either way ... you are correct w/ the heet. I am using prestone windshield washer fluid (it is the yellow one that is sold in the winter .....hence the methanol they use). Dont use any other washer fluid! You sure as hell dont want to be using something that doesnt even contain methanol. When you shake up the yellow prestone fluid you can tell it's not real soapy. "MAKE SURE YOU DO NOT GET THE PRESTONE ANTIFREEZE - IT LOOKS THE SAME" ....they are both yellow containers that look similar.
I would love to see what people are using that cost $1/gallon. I have heard that more then once. The prestone is about $3/gallon which is a lot cheaper then buying strait methanol.
yea its basically a controller, a pump, tank and nozzle with a hose...
