is this all good? dezod turbo system! helpp
Old 07-06-2009 | 05:51 PM
SoFloTC's Avatar
my tranny died after a few months on dezods kit on 6 lbs lmaooo... dynoed 242whp 246wtq.. had a trans cooler aswell
Old 07-06-2009 | 06:01 PM
stillettoDSM's Avatar
Did you have anything done to your Trans? Anything to build it up?
Old 07-06-2009 | 06:03 PM
SoFloTC's Avatar
nope stock tranny at the time.. then i got a built one but that started to slip at 15 psi so i took it out but it was strong at 10 lbs, now its sitting in my garage hah
Old 07-06-2009 | 06:09 PM
I'm gonna' have to buy some of the upgraded components before anything, because by the time I actually have all the turbo parts, my car will probably have like 30k on it.
Old 07-06-2009 | 07:03 PM
BC_Scion_LA's Avatar
yep my tranny is about done to down to 3 gears haha and major slipage but drives fine when not on wot. the waste gate spring i think might be to high deff go lower. i was shooting for 10 psi or 11psi but trans started slipping on dyno made 266hp and 234 tq. built trans next........
You said your trans was hoilding strong at 10lbs? Who built it for you level 10 or ipt?
Old 07-06-2009 | 07:27 PM
SoFlo had Level 10.. IPT says their Built Trans can hold a little more than 400whp, but that's costly.
Old 07-06-2009 | 08:55 PM
SoFloTC's Avatar
ya i have leveltens... it held good at 10 lbs but i put it to 15 and it started slipping but it should not have so i just took it out and went manual.. its just sitting here lmao.. but if someone were to send this tranny back to level10 to get it corrected it would cost hell of a lot less then sending there own because it already has upgraded valve body, upgraded torque converter and new pumps and what not.
Old 07-06-2009 | 09:10 PM
No one's been interested in your Transmission? How much would you want for it?
Old 07-06-2009 | 09:21 PM
im interested now lol. cause my trans is on its last leg
Old 07-06-2009 | 09:22 PM
SoFloTC's Avatar
i havent really tried to sell it, ive been debating whether i should go back to the shop i had do it and have them send it back to level10 or not for a while.. i dont really wanna spend shipping costs to have a tranny refreshed that im not even gonna use.
Old 07-06-2009 | 09:28 PM
Well, I'm currently saving and spending on different turbo parts here and there, so if by any chance I have some cash in the coming months, and you decide to sell it, PM me with a price.
Old 07-07-2009 | 09:21 PM
mjw21's Avatar
so what can i do to fix this trans problem...
Old 07-07-2009 | 09:49 PM
Two Options..
Look up either IPT or Level 10, they are the ones who would help with building it up.
You can either get an Upgraded Valve Body, High Stall Torque Converter, and Upgraded Clutch Packs, OR sending the entire Transmission to either of the two, and they will Re-Build it.
Old 07-08-2009 | 12:02 PM
mjw21's Avatar
$$$$$$$? sounds expensive
Old 07-08-2009 | 03:18 PM
The first route can run you around $1-2k, not so bad really.. that's said to be able to hold around 310whp.
The second route, sending the trans off to be built, that can cost around $4-5k, but it can hold more than 400whp, and usually comes with longer warranty.
Old 07-08-2009 | 07:39 PM
mjw21's Avatar
okay...what about just going manual tho...or is that what we are talking about? lol....like i know everyone says its not worth it go buy a differnet car but i only have 11000 miles on my car and doesnt make sence to trade my car for a manual one with more miles...but how much would it just to go straigh manual and would you have issues with it if u swaped the trans?
Old 07-08-2009 | 07:44 PM
SoFloTC's Avatar
i just swapped my auto to manual for less than 3 grand. check out the therad in the drivetrain section
Old 07-08-2009 | 09:17 PM
paul_dezod's Avatar
Scionetics
KAD
Yes but if stock fluid was used, if you eliminated the stock cooling all together, drove with your foot to the floor board and ran 6 PSI, of course the trans will fail.
We ship the kit with 5 PSI for a reason. We know it holds and works if you don't beat the snot out of the car, run your trans cooler AFTER the stock cooler AND run a synthetic fluid as well. Simple as that.
Heat is the #1 reason for trans failure. They heat up, cook the fluid and bye bye trans
Old 07-08-2009 | 10:13 PM
SoFloTC's Avatar
well thats what i did, it comes with a 5 psi spring which i STILL have in my WG to this day but my boost gauge always read 6 aswell as the dyno, either way at 6 lbs if your running a full exhaust system pushing 230+ whp ur tranny will eventually die.. theres no getting away
Old 07-09-2009 | 08:06 PM
I can't believe that.. I'm sure that if you drive normally without ******* it, it would be fine.
