all4degame's unboosted and needs a srs a-pillar HELP!
Old 05-02-2009, 04:04 AM
  #361
CarbonXe's Avatar
The PTuning exhaust comes standard with VBands...
And the PTuning midpipe mates to the stock Spipe. I know because I used that as an exhaust for a month before my turbo install.
CarbonXe is offline
Old 05-02-2009, 04:08 AM
  #362
Syldrin's Avatar
Carb i dont get why you complain about your kit so much.
Syldrin is offline
Old 05-02-2009, 04:13 AM
  #363
all4degame's Avatar
The last portion of the ptuning exhaust, the J pipe it looks like, i thought it was a two bolt on one end and vband on the other. Mine is vband on both sides.
all4degame is offline
Old 05-02-2009, 04:22 AM
  #364
CarbonXe's Avatar
Because the fitment really is horrible. The hot side sits lower than the jack point and was rubbing against a bolt, which was starting to cut through the pipe. The cold side sits lower than the jack point, the BOV touches my hood, the coupler between the two hot side pipes is slightly crushed because it was needed to be positioned at such an extreme angle (essentially, I was given a straight piece to use as a 45 degree piece).
Actually, my BOV hits my hood in two different spots. The adjustment screw on top AND the mouth piece thing.
CarbonXe is offline
Old 05-02-2009, 04:25 AM
  #365
CarbonXe's Avatar
Oh yea, I forgot about that piece. It's a small 8" section that that goes between the Spipe and Midpipe, right?
CarbonXe is offline
Old 05-02-2009, 04:30 AM
  #366
scikotictc232's Avatar
carb you talking bout the driver side pipe how it needs a 45 to connect it to the pipe with the BOV ? I was thinking bout buying a 45 but did not know what the kit came with. I dont want my Black HkS rubbing either but I dont think I will have a problem with that/
scikotictc232 is offline
Old 05-02-2009, 04:32 AM
  #367
Syldrin's Avatar
i see. my cold side sits lower then my jack point. thats my only fitment issue. which with some minor adjusting it isnt that bad. BoV doesnt hit my hood. weird how 2 kits that are the same fit so different.
Syldrin is offline
Old 05-02-2009, 04:37 AM
  #368
CarbonXe's Avatar
No, the kit comes with 90's that you need to cut yourself to make the straight sections and the turbo outlet/throttle body couplers.
CarbonXe is offline
Old 05-02-2009, 04:44 AM
  #369
all4degame's Avatar
Yes sir. That is the right piece.
The truth is, every TT kit is custom and none of them will fit the same.
Stuff that doesn't fit on my V2.1
Downpipe (old one used to hit the oil pan and was nearly impossible to bolt up. )
S- Pipe , This thing wont fit onto my dp.
Cold side IC pipe, its a few inches short where the turbo connects.
My bov doesn't hit the hood and my ic piping doesn't hang low.
Old 05-02-2009, 04:59 AM
  #370
CarbonXe's Avatar
We spent an entire day to get the BOV as low as possible and the IC piping as high as possible, and this is the best we were able to come up with.
Hot side
Cold Side
Failure angle on coupler. It's almost like the pipe was missing an entire 4" 35 degree angled section. Hard to tell, but the coupler is at such an extreme angle, that it doesn't even sit on the piping on the back side.
And the damaged BOV. I put the cap on it so the top screw wouldn't poke a hole through my hood. It actually started chewing away at the inside of the hood.
and sorry for the insanely bright shots. I set my flash to almost max power.
CarbonXe is offline
Old 05-02-2009, 05:04 AM
  #371
the HKS should sit lower than the greddy but I have heard of people having issues with that one also. do you rub anywhere else carbon ?
Old 05-02-2009, 05:07 AM
  #372
CarbonXe's Avatar
Oh yeah, I almost forgot about the one where the bolt almost chewed through my piping. I didn't get a good shot of it, but it's all the way on the left. I wrapped it in header wrap and had to use zip ties to pull the charge pipe away from the bolt. I noticed it about 1 week after I installed the turbo, and it was already more than halfway through.
CarbonXe is offline
Old 05-02-2009, 05:12 AM
  #373
Joyride's Avatar
Ouch, sorry to hear about that. That sucks so much. It must feel like installing a brand new toy you got for christmas and it not working =( my condolences go out to your hardship.
Joyride is offline
Old 05-02-2009, 05:39 AM
  #374
Syldrin's Avatar
Wait wait i got that one too.... you and i did the exact same thing. cut a peice of the silicone and zip tied it up.
Syldrin is offline
Old 05-02-2009, 05:41 AM
  #375
CarbonXe's Avatar
[img]https://i295.photobucket.com/albums/mm157/carbonxe/epic%20failure%20fitment/DSC_0015.jpg[img]
At first I didn't zip tie it, I just used some leftover coupler. The bolt head managed to make it's way through that. So I put some header wrap around it, put another coupler around that and pulled it as far back as possible and zip tied it to the wiring harness bracket on the A/C compressor.
CarbonXe is offline
Old 05-02-2009, 05:45 AM
  #376
Syldrin's Avatar
Is your ceramic coating burning off too?
Syldrin is offline
Old 05-02-2009, 05:47 AM
  #377
all4degame's Avatar
Fitment issues make my head hurt. Sorry to hear you had to endure fitment problems as well.
Well, at least I wasn't the only one. LOL
Old 05-02-2009, 05:50 AM
  #378
Syldrin's Avatar
Meh my kit honestly took a total 6 hours. including welding the oil pan.... which i need to have somone with a proper welder weld me a new one.
Syldrin is offline
Old 05-02-2009, 05:52 AM
  #379
crush02342002's Avatar
dump tube looks like crap...lol...time to recoat
crush02342002 is offline
  #380
all4degame's Avatar
I am continuing my 1 month and 2 week install. lol
Man, chris you're the dump tube king now adays. lol
Quick Reply: all4degame's unboosted and needs a srs a-pillar HELP!
