all4degame's unboosted and needs a srs a-pillar HELP!
Old 05-02-2009, 06:40 AM
  #421
CarbonXe's Avatar
Originally Posted by Syldrin
ooohh, i wouldnt correct my whp if i was a wee bit closer to sea level.
Also, it was hot out that day. I was hitting about 275, and we let the car cool down for 15 mins, and I gained another 12 HP right after that.
Honestly, if we have the same turbo, same kit, same exhaust, blah blah...we're making the same power. Tuning only unleashes a few HP. I'm running an 11.5-11.8 AFR under full boost, and pulling 4-6 degrees of timing at the top end.
CarbonXe is offline
Old 05-02-2009, 06:41 AM
  #422
Syldrin's Avatar
You can't adjust a correction factor. you either turn it on or off. atleast i know you can't on dynojet's superflow's
Syldrin is offline
Old 05-02-2009, 06:42 AM
  #423
Syldrin's Avatar
we do run the same turbo on the same kit with the same exhaust and i pull 5 deg at the top end and my last tune i made 323 on 10psi.
Syldrin is offline
  #424
CarbonXe's Avatar
Which xB?
Some xB that No Limit tuned. It's running a custom kit with a treadstone manifold and a 50 trim. it's a slightly bigger turbo than mine, but not 50whp bigger.
CarbonXe is offline
Old 05-02-2009, 06:43 AM
  #425
Syldrin's Avatar
Wait what size turbo do you run? i run a 60trim .82 A/R
Syldrin is offline
  #426
CarbonXe's Avatar
On a dyno dynamics, you can set any correction factor. They set a 10% to prove it and I gained 30whp instantly. A lot of tuners use it to make their job easier. If a car comes in and the guy wants 300whp, they can just give it a basic tune, set a correction, and voila, the customer is happy.
CarbonXe is offline
Old 05-02-2009, 06:44 AM
  #427
crush02342002's Avatar
damn i only made 298hp 301tq @ 11psi
crush02342002 is offline
  #428
CarbonXe's Avatar
I'm running a 57 trim .63 A/R.
CarbonXe is offline
Old 05-02-2009, 06:45 AM
  #429
CarbonXe's Avatar
Yea, I was told that on a dyno jet, I'd make about 330-335WHP.
CarbonXe is offline
  #430
i think i was pulling much more timeing though and iv got the .82ar hot side .60ar cold side stage 5 wheel
Old 05-02-2009, 06:46 AM
  #431
Syldrin's Avatar
Ah i see. ya i run a lil bigger turbo. my freaking AFR's are hitting the 10's again its annoying not having a laptop so i can just adjust the long terms myself.
my max tq was 329
Syldrin is offline
  #432
correction HAD
Old 05-02-2009, 06:48 AM
  #433
CarbonXe's Avatar
That's how big of a difference a dyno makes lol. I mean honestly, the only thing it's good for, is to be used as a tool for tuning. They can make it read whatever number they want it to read, but that's exactly why I drove 5 hours down to PTuning to get tuned, because I knew they were going to give me a great tune with realistic numbers. If I went to RIPP mods, I would have bought a base tune for $400 and made "more" power.
CarbonXe is offline
  #434
take that back i was only pulling 4 degrees of timeing...bahh
Old 05-02-2009, 06:49 AM
  #435
CarbonXe's Avatar
my max tq was 329
It's relearning?
CarbonXe is offline
  #436
Syldrin's Avatar
i ran on another dyno around here. it was a superflow. which they read lower and i made 319 and 330 tq.
Syldrin is offline
Old 05-02-2009, 06:50 AM
  #437
CarbonXe's Avatar
I want to go down to a shop that's like 10 mins from me, but I don't want to spend $75 for a dyno session. They have a dynojet...I just want to see how much of a difference it really makes lol.
CarbonXe is offline
  #438
Syldrin's Avatar
my max tq was 329
It's relearning?
it always is.
thats why i have yet to post a dyno sheet. i could careless if people believe me. i'll put up a track slip when i get one but i have training to focus on and a gf that i want to marry. so honestly my car is on the back burner.
Syldrin is offline
Old 05-02-2009, 06:51 AM
  #439
Syldrin's Avatar
i bet you can ask for 1 pull for 45 bucks.
Syldrin is offline
Old 05-02-2009, 06:52 AM
  #440
idk the dyno i have always used is pretty close i think...stock i dyoed at 144hp 150tq I/E
Quick Reply: all4degame's unboosted and needs a srs a-pillar HELP!
