all4degame's unboosted and needs a srs a-pillar HELP!
Old 05-02-2009, 08:06 PM
  #461
all4degame's Avatar
hahaha thanks chris! I'm just really glad that my downpipe isn't having butt sex with my oil pan anymore. Atleast anything that needs to be fix, I can fix it on my own at an exhaust shop.
all4degame is offline
Old 05-02-2009, 08:27 PM
  #462
scikotictc232's Avatar
I didnt mean the coat throwing it off I am talking bout just removing it. is it safe to do so ? so i can send it in and get it coated ?
scikotictc232 is offline
Old 05-02-2009, 08:32 PM
  #463
all4degame's Avatar
It should be fine. I didn't do the coating myself, Todd did.
I'm going to leave my dp raw, there is no way I'm taking that flange off again. And even if I do, I'd probably would scratch off all the coating when i try to get the flange back on.
Old 05-02-2009, 08:35 PM
  #464
Cwatz5219's Avatar
LOL. Thanks crush. I most likely will end up sending you some stuff, if I ever get this damn this.
Yeah that mani is pure sex.
Hey chris I'm still trying to get my boy to start a thread for your kit that he bought. He's being an ars. LOL. But hey if he don't then that's better for me cause then I can start my TT Rockland County, NY thread
Cwatz5219 is offline
Old 05-02-2009, 08:36 PM
  #465
haha ^ if you ever get it that is. .
Old 05-02-2009, 09:11 PM
  #466
Ronin Scion
Ace83's Avatar
dp looks better kev, but you can always disconnect it from the vband connection not the 4 bolts if you decide to have it coated
Originally Posted by scikotictc232
If my pipes dont fit higher than what they are I think I am just going to say flip it and weld my own. its not that hard and I am sure it will fit better in the long run. plus I want to run a 3 inch from the cold side up to net a few more horses. I wanna dyno with the tt ones first and then do mine and redyno and see how much more power I can make from my own mod.
what turbo are you running? usually a 2.25" will get get you efficiently close to 500hp, a 2.5" about 600hp.. so a 3" IC pipe will be an overkill for you, IC pipe is something you dont wanna over kill or you will just lag without benefit..
Ace83 is offline
Old 05-02-2009, 10:10 PM
  #467
all4degame's Avatar
Can any of you guys with oil pressure sensors give me how the car is suppose to be have in gear, out of gear, ect psi wise? I'm not really familiar with how much oil pressure there is suppose to be at idle, in gear, out of gear and what not.
I just drove my car around for a bit, and it stalled while rolling three times inbetween shifts. doh. I need to finish up this exhaust and get a tune quick. I miss my car.
Old 05-02-2009, 10:14 PM
  #468
Ronin Scion
Ace83's Avatar
oil temp vary with temp but shouldnt make much difference between shifts... hot idle is like 8-12, cruise is around 50-70psi.. the stalling should be on the tune not the oil pressure
Ace83 is offline
Old 05-02-2009, 10:35 PM
  #469
all4degame's Avatar
Awesome. hot idle i'm at about 10-12psi, cruising in gear i'm about 40psi. In gear off throttle i think i'm at 20psi.
and yea, the tune is the stalling problem for sure. I'm heading back to school to start studying for finals, this project will be continued next weekend.
Old 05-02-2009, 10:53 PM
  #470
crush02342002's Avatar
the psi level will go up in revs...doesnt matter what gear your in....mine went like this
first start on cold engine (didnt matter the ambiant temps out unless it was extream 40-30f...ect)= 67-70psi
few seconds after first start (idle)= 60psi
gentle excel to 3000rpm after 2-5mins of running= 60psi
hot idle= 9-12psi
running hot at 3000rpms= 40-45psi
crush02342002 is offline
Old 05-02-2009, 10:55 PM
  #471
hey kev you got greddy blue huh? then my tunes are no good for ya
Old 05-03-2009, 08:13 PM
  #472
all4degame's Avatar
yeah, i have the blue. I'm going to have my buddy do a street tune for me, and then we're going to hop on a dyno later this month and do a 9 psi tune.
Old 05-04-2009, 02:06 AM
  #473
jsg93085's Avatar
hey, question for the fellow boosters... what is your vacuum reading when idling once the engine has heated up?
mine reads between 16 and 18 in/mm Hg... a friend made a comment that is a low amount of vacuum for an engine to be pulling. i think it might be the gauge though.
thanks
jsg93085 is offline
Old 05-04-2009, 03:37 AM
  #474
CarbonXe's Avatar
That is low. I idle at 21-23Hg.
CarbonXe is offline
Old 05-04-2009, 03:48 AM
  #475
all4degame's Avatar
I'm at about 21-23 as well. Target afrs are suppose to be at about 14 right guys?
Old 05-04-2009, 03:50 AM
  #476
I am running a Garrett 60A/r cold .82 A/r hot T3 turbo. I was not planning on running a full 3 inch but a 2 - 2.5 inch hot side and a 3 inch cold side out of the inter cooler. would that still harm the performance ?
Old 05-04-2009, 04:04 AM
  #477
jsg93085's Avatar
ok, then its probably the gauge. all vacuum lines are clamped down... i'll probably buy a new one later this month...
yes kevin, target afr's for idle are in the 14-15 range, mine jumps from 14.7-15.6 or so when idling, but its getting hotter out here
jsg93085 is offline
Old 05-04-2009, 04:53 AM
  #478
all4degame's Avatar
My car is running über rich. I'm at low 12s at cruising speeds. I need to finish up this exhaust and get a tune.
Have you figured out your creep issue yet josh?
Old 05-04-2009, 10:44 AM
  #479
my vac as well as TheFantasticG always ran 20 inhg vac (in idle) and 24 on decel (like that really matters )...if im not mistaken Carlanga is running the same vac
Old 05-04-2009, 12:15 PM
  #480
jsg93085's Avatar
the creep issue may be a faulty boost gauge... lol, i have a friend who has a boost gauge that isn't being used so i am going to see if i can borrow it to verify that the issue lies with the gauge...
jsg93085 is offline
Quick Reply: all4degame's unboosted and needs a srs a-pillar HELP!
