all4degame's unboosted and needs a srs a-pillar HELP!
Old 06-09-2009, 01:26 AM
  #981
crush02342002's Avatar
Originally Posted by scikotictc232
^ wish my scion homies in my area thought like that. They are Va J J's and scared of boost though. I would say keep the set up man and just swap a new motor make sure it runs and since you will have your gauges in before you can monitor everything for a few weeks - month what ever and then just swap it back in. I doubt it was the kit man does not make sense. Going boosted is definitely money consuming man. I have to save to go to school and finish my car. It will be worth it, probably is already. Reason I say is look at all the knowledge that has come from this.
word
crush02342002 is offline
Old 06-09-2009, 01:51 AM
  #982
all4degame's Avatar
You know man, that is exactly what my mom said when she was trying to cheer me up. lol. I've learned a lot from this process. I'm going to hang on to the kit for a little while, but I'm going to sell my emanage, pnp harness, and support tool. If I return to boost I'm going to use the fic. I messed with carlos's fic and it was SO much better than the emanage software.
During the motor swap I think i'm going to go with a CC stage 3. This disk should be pretty streetable for NA use, and should be able to hold power to the turbo if I do decide to go turbo again in the future. If I go turbo again, it will be a low boost application of like 6psi or so max.
all4degame is offline
Old 06-09-2009, 03:26 AM
  #983
thendawg's Avatar
You should def do the swap yourself - you seem to be pretty mechnically inclined and its really not that hard - your first motor swap will take about 12-15 hrs to pull the motor than 8-10 to go back in than it goes down from there - i can do a complete swap in about 8 hrs lol
thendawg is offline
  #984
thendawg's Avatar
If you need help im sure i could make a trip up there for a weekend to give you a hand
thendawg is offline
Old 06-09-2009, 03:40 AM
  #985
all4degame's Avatar
I did a motor swap last month on Crystals tC. Its a two day project for sure. I would do it myself but I don't have the time to do it.
Old 06-09-2009, 04:49 PM
  #986
all4degame's Avatar
Since i'm swapping motors, I'm going to replace the clutch while I am in there. Just for future longevity, and possibly low boost. I need something that I can daily. I have a stage 5 sitting in the garage, but I'm thinking that's not a good idea for NA. lol Opinions?
Old 06-09-2009, 05:04 PM
  #987
CarbonXe's Avatar
It doesn't matter what clutch you're running for N/A street use, because you'll never surpass the limits of it. The only thing you should worry about, is how much power you plan on making down the road and the drivability of the clutch. I'd say go for stage 4. Very easy to drive (takes a day or two to get used to) and is good for 350WHP. Plus if you're driving around N/A for 6-12 months with it, you won't even put a dent in the longevity of it.
CarbonXe is offline
Old 06-09-2009, 11:06 PM
  #988
all4degame's Avatar
Which stage 4 jon? CC or CM?
Old 06-09-2009, 11:18 PM
  #989
Ronin Scion
Ace83's Avatar
which ever you want.. i have CM and its great no issues
Ace83 is offline
  #990
coryjames's Avatar
steer away from clutch masters i blew my stage 5 on street tires with 500-1000 miles on it they wont warranty it and the said i was a scammer here is my link to my troubles go comp or act ftmfw
https://www.scionlife.com/forums/viewtopic.php?t=259430
coryjames is offline
Old 06-09-2009, 11:21 PM
  #991
Ronin Scion
Ace83's Avatar
the only thing w/ CC is that I've seen few stage 4 prematurely failing.. not sure if that has been fixed or not.. if not look into act stage 4 street disc, its interesting how driveable those are
Ace83 is offline
Old 06-09-2009, 11:26 PM
  #992
weezyfbayba's Avatar
ive got a stage 4 CC clutch gonna install it as soon as i get my mounts
weezyfbayba is offline
Old 06-09-2009, 11:28 PM
  #993
coryjames's Avatar
i will be running the act street clutch a special one made to hold my power
Old 06-09-2009, 11:38 PM
  #994
all4degame's Avatar
ACT clutches are pricey!
Old 06-09-2009, 11:51 PM
  #995
i havnt heard too many complaints about CC....actualy i cant think of any one who has complained about cc...idk...im sure someone has..lol
Old 06-09-2009, 11:57 PM
  #996
CarbonXe's Avatar
Clutch Masters. I've had it for 7000 miles so far and 0 issues.
I'm going to go ahead and blame 90% of clutch failures on improper installation/application and/or abusive use.
CarbonXe is offline
Old 06-10-2009, 02:15 PM
  #997
Cwatz5219's Avatar
I had the stage 4 CC clutch and it blew on me last month. Barely had it on for a year and they won't warranty it.
I'm not even boosted yet
Cwatz5219 is offline
Old 06-10-2009, 02:18 PM
  #998
Cwatz5219's Avatar
Old 06-10-2009, 04:31 PM
  #999
all4degame's Avatar
what in the world? why are all these clutches blowing so early?
Old 06-10-2009, 08:25 PM
  #1000
Ronin Scion
Ace83's Avatar
i know there was an issue with CC before not sure if its related to the early failure... but yeah even act had issues before but havent heard any recently
Ace83 is offline
Quick Reply: all4degame's unboosted and needs a srs a-pillar HELP!
