Alpha Series
Not to say this turbo is laggy by any means, because even with an .82 A/R turbine and a 3" exhaust this turbo made 19 PSI by 4K RPMS. Hardly laggy.
http://www.dezod.com/pd-dezod-motors...m-tc-05-10.cfm
In keeping with the spirit of scion and the ever-so-changing need to be original and "define yourself", we here at Dezod Motorsports have decided to make this a reality with the release of our Alpha Series Turbo Tuner Parts.
The Alpha Series Scion tC turbo tuner parts where developed and intended for the advanced tuner, whom wants to make 500+whp on their 2AZFE and have a custom setup along with it. We supply you the following components:
Dezod Motorsports Alpha Series Tubular Turbo Manifold
Dezod Motorsports 3" Race Downpipe
Dezod Motorsports 3" S-pipe (must be custom fabbed to fit your exhaust)
Dezod Motorsports Dump Tube for 44mm TiAL wastegate
TiAL 44mm wastegate
Garrett GT3582R Turbocharger with TiAL v-band inlet/outlet turbine housing
-4AN stainless Braided Oil Feed Line w/ GT Ball Bearing Oil Restrictor
-10AN Push Lock Oil Drain Line
-10AN Pan adapter Fitting
What the tuner must do is make their own intercooler setup, blow-off valve of choice, fuel & engine management choice as well. It doesn't matter if you want to run standalone or piggy back engine management, large FMIC air/air intercooler or water/air intercooler, the choice is yours 100%. Do it yourself! We simply provide the hardest parts for you and your fabricator.
With the proper components placed together, this system is capable of 600HP!
TiAL 44mm wastegate
Exactly. Your situation and new turbo comers looking for big power, but with the element of customization where EXACTLY whom we where targeting with this system.
The idea was to produce an upgrade kit for the Scion owners who already had a turbo kit but did not want to purchase an entirely new kit. These replacement parts can be used with what you have already installed on your car.
You would need the manifold, downpipe, dump tube, oil feed and drain & turbo. Then you need refab a new intake pipe for the turbo. Cut the lower hotside pipe for the new turbo. Make your exhaust mate to the new 3" V-band S-pipe.
