Aluminum Rad in!!! What a Biatch!
#49
Originally Posted by java09
when you do i mean.
when I do..."is" what I mean... No shots of my engine bay are allowed, it's considered G14 Classified....
#55
#57
I say just about a cm or 1/2 an inch the most, but the oem fans are mounted in the shroud right so it might just be same as stock, cant really remember how the stock fans are mounted
#58
I think theoretically, it should be half of the increase in width. So if the Mishimoto is 30mm thicker than OEM (just as an example), then I think that each side off of the center mounting point should extend out 15mm more than normal.
If this is correct, I would love to know exactly how much thicker the Mishi is vs the OEM.
#60
I'm curious why would you change the radiator? I would think changing the thermostat would work just fine for these cars. I;m just curious because I received my 170 degree thermostat from Gates and maybe I should change both to save time.
