Another Dezod Kit! **UPDATES**
Old 12-14-2006, 06:12 PM
  #101
Prototype_xB's Avatar
Originally Posted by paul_dezod
Niiice!!! (Minus the $276)
Haha, yeah. When i talked to ya yesterday i told ya something like $158. Thats the price the parts guy gave me over the phone. When i went today to pick it up he tried to give me a secondary oxygen sensor. So i had to ORDER this one. Will arrive and pick up after work tomorrow. So thankfully this isn't hindering my install
Prototype_xB is offline
Old 12-14-2006, 11:49 PM
  #102
firesquare's Avatar
hey, by the time i come up though it will be dark. dont wait up for me. but ill be up after work saturday. bout 6:30 ish
call me as soon as the manifold hits your doorstep.
firesquare is offline
Old 12-15-2006, 12:15 AM
  #103
/\/\ Its all cool man, probably won't be until dark when i get it running anyways. Getting off work at 3, then the exhaust filler stuff i bought to fill in the slip fit dump takes 4 hours to cure, then maybe another 1-2 hours for final install, so i'm looking to be up and running by 9-10pm tomorrow night
Old 12-15-2006, 12:45 AM
  #104
zer0's Avatar
Yea, crossthreading FTL!!! It happened to my Spipe sensor, and I had to dremel the threads back, works well..
Congrats
zer0 is offline
Old 12-17-2006, 04:30 PM
  #105
**UPDATE*** 12/17/06
Alright guys! The kit is 100% in and running!! I had a bit of a hinderance due to a problem with poping EFI fuses which was at fault for the secondary O2 sensor having it's outer wire covering melted through and touching a piece of metal attached to the block which all your EFI componets ground to, so i kept shorting out and popping fuses. The car had to spend the night at Target on its maiden voyage out to town because of this. Thanx a ton to Joe and Paul over at Dezod for helping me brainstorm on possible culprits to this problem.
So anyways, back to the kit. This kit runs STRONG!! The base map is exactly what it means, pretty base . Runs very rich under full throttle in boost and boggles a little in between gears. Getting a custom retune hopefully in 2 short weeks (gotta baby it til' then). Did the install entirely myself and only had minor issues. The biggest was a small fitment issue with the wastegate to the manifold and the dump flange into the downpipe. Wasnt' exactly perfect but after a bit of persuasion, i got it to see things my way, haha. Install went very smooth, however it was a pain in the neck, LITERALLY:
I pulled a muscle , or rather the doc said it was a muscle spasm from extreme exersion. (I look awful cuz i just woke up from trying to sleep in the neck brace all night. I guess that's what you get after lying on concrete all day. Haha, but in all seriousness the install went very very smoothly :D.
So impression of the kit thus far:
The turbo is LOUD. VERY LOUD! With the closed dump you can hear the compressor spooling up and screaming right in your ear! The bov, OMG! The BOV is the loudest freaking thing i've ever heard! (HKS SSQV with purple insert). The best part about the kit is the a/r housing on the exhaust side. It's a .48a/r and builds boost VERY quickly. You can build a pound or two simply by reving up on it. This is very very exciting to me because i use to have a turbocharged civic. I had a ball bearing garret T25 on it but the exhaust housing was an .80a/r which you could redline the car by reving up on it and build absolutely no boost what so ever. So with this turbo you can give it a nice good rev and PSSSSSSSSSSSSHHHHHHHHH! SWEET! Very very nice for when you want to "communicate" on the street . The car pulls very hard but with an AFR of ~10.5 there's lots more power to be gained with a retune.
Pics:
Here's the secret to making all the POWER:
Old 12-17-2006, 04:45 PM
  #106
zer0's Avatar
Looks good. Congrats again.
zer0 is offline
Old 12-17-2006, 11:03 PM
  #107
Joe_Dezod's Avatar
Niiiice man. Glad it's working out well for you!
Joe_Dezod is offline
Old 12-18-2006, 01:49 AM
  #108
SCION_X's Avatar
Awesome write up... good luck with everything.. I will be going ZPI all motor(long block stage 2) and Turbo sometime in the next year...
SCION_X is offline
Old 12-18-2006, 02:29 AM
  #109
ERIC-TC's Avatar
The Dezod kit should come with a disclamer that says
WARNING!! Before pressing gas pedal, be sure to firmly press your head agisnt the head rest- Or else you will end up like this...
ERIC-TC is offline
Old 12-18-2006, 04:21 AM
  #110
Old 12-18-2006, 04:35 AM
  #111
zer0's Avatar
Problem area pictures? Plz?
zer0 is offline
Old 12-18-2006, 04:45 AM
  #112
/\/\ I will as soon as my neck get better. Last thing i need is to crawl under the car and have it go out again
Old 12-19-2006, 12:46 AM
  #113
Kumitsu's Avatar
Dood that kit looks sick man, happy boosting.
Kumitsu is offline
Old 12-19-2006, 02:48 AM
  #114
mike6789k's Avatar
hold on one second! you put that sillicone sealent stuff on the INSIDE of your oil pan?!
UH OH! that cant be good..... not to mention the over applied sealent around the pan.... thats all going to end up in your engine oil!
and to think we were worried about teflon! LOL
mike6789k is offline
Old 12-19-2006, 02:59 AM
  #115
zer0's Avatar
WTF are you talking about? You need to make a bead around the pan, for the oil pan to seal...
zer0 is offline
Old 12-19-2006, 03:08 AM
  #116
mike6789k's Avatar
i know, but look how much he used... not to mention he used some on the inside of the pan where the hot oil will actually be TOUCHING... ouch..
Old 12-19-2006, 05:34 AM
  #117
Scikotic-tC-'s Avatar
you dont think the hot oil would touch it when its making a gasket?
Scikotic-tC- is offline
Old 12-19-2006, 06:00 AM
  #118
Byta27's Avatar
look under the car man and check for leak were u punched the pan cause i had alot of problems with that just looking out for u, i had to get the supercharger pan.
Byta27 is offline
Old 12-19-2006, 05:15 PM
  #119
No leaks, i've kept a close eye on everything
  #120
It will hold
Quick Reply: Another Dezod Kit! **UPDATES**
