Another Dezod Kit! **UPDATES**
#144
Originally Posted by Kumitsu
Originally Posted by Joe_Dezod
Problem fixed at least
Thanks Matt.
Thanks Matt.
#145
Originally Posted by Byta27
those pictures that matt took are identiacl to the problem i am having i cant fit anti fouler in there cause as u can see it just barely fits just with the o2 sensor
#150
im still running stock, stock plugs happen to be very good.
Congrats on the kit XB, good to see you are getting everything together. I'm hoping to have my kit lined up here in the next month. I'm trying to look down the road quite a bit ancticipating a built block/head and the ability to hit 400+ whp mixing reliability. Dezod seems to put out a good product and a lot of people are happy with it.
Keep us posted, bro!
-cz-
#151
#153
/\/\ my civic made a weird squeaking noise when mashing in the clutch pedal and when letting it out. Oddly enough it ended up being the plunger seal in the clutch master cylinder. Sound like rubber squeaking agasint metal?
#154
#156
my car is making an unusual sound now, it is making a squeaking noise when i let off the clutch, i dunnno maybe my clutch or maybe oil, how could i check if the tranny oil is low?
might not be that, but just suggesting a possible problem. try to pinpoint where the sound is coming from.
#157
well i got the sqeaking from the clutch which im not to worried about prob no biggie the only thing that i am is a sound that i just found out tonight is come from what sounds like the axle back of the exhaust, it could be or maybe new rear pads?. i took a look at the exhaust and i didnt hear any leaks at idle it sounds fine whenn i get started in first and bring it into like 3-5 psi u hear it but then at wot u dont. ughhhhh cant take this crap i just want it to be problem free seems like i have somthing all the time.
#158
**UPDATE**
Alright guys, here's a pic of the work i had to do on the s-pipe to fix the bung location and run anti-foulers. Byta27, you should like this, haha :
(The closest sensor to that CV bearing hub is the sensor for the AEM UEGO and it is NOT touching, about 1/2 " away. Just so ya know. The pic makes it look like it's touching)
And the best part!!! \/\/\/\/
NO CEL!!!!!!
NO CEL!!!!!!
