Another problem... This time Tranny related.
idk but building a tranny is going to cost a ridiculous amount.. plus idk if i like the idea of the xrs gears for boost.. i read the thread and i think travis and some others said it wouldnt be at all positive for boost? idk. this tranny lasted 50 dyno pulls and a year. so.. i mean i dont need to dyno anymore.
Would NOT put an XRS tranny on a tC by anymeans. Those things will EXPLODE unlike our tranny. And they will explode at a mear 250whp. Our trannies don't do that. Our problem usually lies within the gears/synchros. But never does the tranny completely fail, not even at 600whp. Gears on the other hand and especially 4th gear will be a headache for you. I need to learn to rebuild them.
Soflo, do you have an LSD?
yea we had to take it apart to fix the clutch. he put everything back perfectly and even rechecked it a few times as hes a perfectionist. but ya im thinking the diff went... i mean theres just no way i lost teeth on all the gears.. and if the diff blew then im guessing it caused the leaking fluid aswell.
Cory, yea we had it apart but if you have ever had one of the trans apart you would see/understand. Theres only one way to put it together. cant work for 400 miles then come apart. Unless you completly forgot to put something in. Expecially when you redlock tite everything like myself lol! Plus we pulled it apart to replace the case and learned that there are 2 versions of the case so i just slapped it back together not changing anything. but good call at first i was like uhh dammm.
But what i think happened here is possibly diff related.
Since when he called me. Said 5th gear just reved out. then he tried 1st it worked then reved out. tried 2nd worked then reved out.
There is no way that all 5 gears broke. And expecially if the issue started in 5th which is seperated from the rest of the trans.
Anything is possible and once its torn down we will find the issue! But i will say this trannys been through hell. And im not sure anyone making this power on an open diff like he is.
The car currently is rapping tires from 50-100 mph, and chads no stranger to doing that!
Luckly around the orlando area trans can be had for 250-300 dollars. Will keep everyone updated!
i rebuilt mines for under 1k even with chryo treatments... its not expensive if you do your own labor and know what to do. I know who to talk to and know plenty of industry people with good tech info to back me up. not doubting trav, but i did what i did for a reason and since trav is not behind the wheel of my car nor has anyone else here other then a friends of mines and rob(breal) no one knows how the tranny i have works and how certain gears from the XRS can hold power and are an advantage for boost apps. Im on alot of forums (much more technical then this site) and plenty of even old school toyo ppl who build rear race cars and track cars especially in PR can attest to doind something similar ive done and drive 4-600 whp 3tc's, mr2s, and echos daily.
I NEVER SAID I HAD AN XRS TRANNY LETS GET THAT STR8 THAT WOULD BE IN ITSELF A STUPID MOVE...
this is why i rebuilt mines with a combo of mr2/xrs/ and tc.. but if you remember it was something i clearly said. even with the mr2 final drive upgrade.
im gonna really try to get a video so u can see. but you can ask Breal.. my tranny would be a fantastic boost upgrade. and i know for a fact im not the only tc guy with this tranny combo as there is one in PR who makes 575 whp
daily driven and tracked with no problems and another old guys locally with a silver tc whose had his car built from (toyomotos old days) lance. THAT car drives around 550 and its been on that tranny tracked at moroso on slicks for well over 2 yrs now and it drives amazing with no slippage or issues. he races turbo hayabusas for fun
You mean manuals trans dont like running on no fluid?
LOL!
Im anxious to see what happened to his, because it wasint leaking untill this happened! so possible diff expolsion?
If your diff failed, it would be a first in history. Of all the cars out there, including PTuing's TA car, they ran on open diff on the track before as well. So, never heard of a diff failure in our tranny.
TCpete, keep in mind that I was not referring to the use of XRS "gears", but just the notion of using an XRS tranny like someone else said. Then again, the only XRS tranny that could be used is the 09 XRS. I was referring to the faster previous XRS Corolla. Their trannies blew up if you tried to launch the car with anything more than 250whp. Some I've heard fail with less power cause the guy launched to hard.
I would double and tripple check the axles before EVER touching the transmission. Giggling it around is not a means of testing. You should pull the CV joint apart and inspect the axle. Make sure the snap ring is still intact. Start with the simple stuff first.
