Any methanol injection for the future?
Old 07-16-2006, 09:20 PM
  #41
nd4spd_4_a_tc's Avatar
I just saw 2 Tcs Get dyno'd with Ripp Mods Meth injection.
Ripp installed them, Then they went on the dyno.
Great results. Very impressed with the over all power band increase.
I know there both members but i did not get there screen name,
Maybe they will post up.
nd4spd_4_a_tc is offline
Old 07-16-2006, 09:23 PM
  #42
zer0's Avatar
Yea its been proven that Meth/Injecton and engine management work wonders for the S/C application. RIPP can hook you up.
zer0 is offline
Old 08-04-2006, 09:37 PM
  #43
PghtC's Avatar
well I got my snow performance MAF stage 2 system today. It looks like it is pretty simple to install. I believe the hardest thing about it is going to be finding a place to mount everything. we shall see.
PghtC is offline
Old 08-05-2006, 04:09 AM
  #44
jwaggz82's Avatar
i think you are correct.
jwaggz82 is offline
Old 08-05-2006, 02:27 PM
  #45
PghtC's Avatar
well I think I found a place to mount the tank and the pump. So whenever I get the chance to install it, I know where I will be putting that stuff. As for the control modules (water/meth control and safeinjection module), well I'll have to see about that one. I need to find a readily acessible area.
PghtC is offline
Old 08-05-2006, 03:30 PM
  #46
Team No Limitz
Simplyscion's Avatar
I think I am going to be running the pump and tank in the rear hatch area so I dont hafta squeeze everything into the engine bay
Simplyscion is offline
Old 08-05-2006, 03:48 PM
  #47
PghtC's Avatar
Yeah I thought about that, but I just don't want to have the pump or the tank for that matter inside the car. The pump will easily fit under the battery tray (lots of room) and the tank will fit between the bumper and the radiator and will be fillable through the opening between the bumper and the radiator support.
PghtC is offline
  #48
jwaggz82's Avatar
you can put the pump by the front bumper
jwaggz82 is offline
Old 08-05-2006, 03:49 PM
  #49
PghtC's Avatar
See my post above.
PghtC is offline
Old 08-05-2006, 04:13 PM
  #50
jwaggz82's Avatar
ha - you posted that while i had the page open typing mine. and yes - that is a good idea. Also - if you guys wanted you could just not use the tank given w/ the kit and just use the washer fluid bottle - its up to you.
jwaggz82 is offline
Old 08-05-2006, 04:16 PM
  #51
PghtC's Avatar
I will not use the washer fluid. It allows too much room for error. If I don't buy the correct fluid and it has bad detergents in it or something it could hose everything...including the motor. I want to be sure that it is getting pure distilled water and pure methanol...nothing else.
PghtC is offline
Old 08-05-2006, 04:28 PM
  #52
jwaggz82's Avatar
nnooo - I didnt type that right. Use the washer fluid holder (the plastic thing). Its 1 gallon'ish and prob 3x's the size as the one you got w/ the kit.
jwaggz82 is offline
Old 08-05-2006, 04:30 PM
  #53
Team No Limitz
i was thinking about doing that being that my kit came with the bulkhead fitting to tap into the resevoir but I was talking to someone and they brought up a really good point and this would affect you guys being that you live in the northeast as well...winter time without a windshield washer fluid tank is deathly up here with the snow and salt on the roads...that alone persuaded me to go out and just buy an alternate tank instead.
Old 08-05-2006, 04:31 PM
  #54
PghtC's Avatar
right, but I don't want to wash the window with my methanol mix. I guess it is just preference. I plan on having 2 separate reservoirs. I want to still be able to use the cheap washer fluid, not my more expensive methanol mix.
PghtC is offline
Old 08-05-2006, 04:37 PM
  #55
jwaggz82's Avatar
if you have AIM - IM me. I would like to talk to you about a few things.
jwaggz82 is offline
xBrelease08
Scion xB 2nd-Gen Wheel & Tire
12
02-29-2016 05:39 AM
greytc
10-26-2015 07:53 PM
prescottn
10-08-2015 05:31 PM
Subaru86
07-31-2015 04:00 AM
Mpwr
07-17-2015 08:39 AM
Quick Reply: Any methanol injection for the future?
