Anybody Running a Dog Box?
Re: Anybody Running a Dog Box?
Originally Posted by Erikos
You are talking to a drag team. I'm pretty sure they have done the research and drag passes to back up what they are saying.
If your looking for dog gears for you car i can help you with that. The only reason i say that stock last longer is there is alot of maintenance in the dog gears.
Thanks for the input all, I was seeing if you all were running enough hp and having enough problems to warrent upgraded gears, but it seems that not enough of you are there and those who are don't really want them.
Congrats to Toyota, who apparantly made a box that has no problems with 300-750hp.
If anyone has a need for upgraded gears let me know.
Originally Posted by darkscion
Wow, I figured if honda's are using them, so would toyota. Thanks for the info.
as far as i know a "dog box" is just a set of gears and a diff,that is installed into your factory case.not a new trans,so theres no trans to buy.and a complete setup for a integra gsr trans is 5k,i couldnt see a tc trans being much more than that.i know of 4-5 local guys running that exact setup on the street in there sfwd cars.
your right...technically "dog boxes" are just a set of gears with "dogs" that fit into slots on the receiving gear eliminating the use of synchros. but the term "dog box" is also slang for the sequential transmissions found in road racing and rally...which is what i thought he was referring to.
oh,my bad.
Originally Posted by draxcaliber
well, 318_tc made 454 whp with a turbo and stock head, upgraded clutch, like a stage 5 or 6, and reinforced drive axles. don't know how much he did to the engine, but i dont' think he did anything to the tranny other than an LSD.
I'm pretty sure he did not. And he didn't have an LSD yet either. On another note, you don't need upgraded axles to run 12's. I'm pretty sure you can break 11's without needed axles. Just good driving skills.
12.1 has been done with the stock axles.
Originally Posted by Resu
So I take it you work with production of dog boxes etc?
Erikos
I'm sorry but i thought you were looking for gears not trying to sell gears. I already have a source for gears, but i would like to get a quote from your source. Please PM me with quote.
^^I would like to know who makes Anything for our tranny. As mentioned, the tranny holds more than 99% of us probably will ever be running on the streets, but I have had to replace my tranny 2 times due to synchros going out. My boy Rich had to have his sync's rebuilt as he lost 3, and 5th gear and he just has a S/C'er on his car.
I just have to swap in the spare I have.
Is there such a thing as beefier Synchros (i.e. made out of stronger material or something)? If I could have those, it would be optimal for a street application that has enough power and crazy enough driver to break the syncrhos.
The tC tranny can handle 500hp. The synchros are more or less a problem though for people who shift without lifting...
No, I use the clutch. Power shifting is never taking your foot off the gas. That's shifting without lifting.
Shifting without lifting provides benefits in keeping the turbo at peak boost. If you have a boost gauge, and you shift normal, you will see the boost drop, and then have to build back up. If you are Power shifting however, all you are going to see is a blip of the needle, and when you catch that next gear, there is no "building" of boost, as you don't drop in boost due to keeping your foot planted on that gas.
That's how I break synchros. However, my boy with the TRD S/C'er and every bolt-on had his 3rd gear synchro and 5th go out and he doesn't power shift. He's a little rough on shifting, but he doesn't power shift.
Power shifting is also referred to as "flat" shifting.
I never power____ either, and my trannys is screwed up.
