ARP Head Stud Install and hand tight..
Hey guys, need some help with tighten ARP Head studs, if you guys use any thread sealant or lock tight or Moly lube on the head studs,? (on the short block/bottom end)
I'm kind of iffy just hand tighten them. Right now i use a glazed coating of Moly lube on them and gorilla hand tight them with an Allen key.
Will I be OK?? Thanx..
__________________
__________________
the head studs should have came with lube...if not i hear oil is fine...like a 10w30....and you dont need to tighten em anymore with an allen key....once the heads on tighten the nuts to 35,60,80
so moly lube is ok?? on the bottom end of the block. i was reading somewhere that if its in the water jacket area you gotta use thread sealant but i already used moly lube on it and hand tighten them... i guess it should be ok.. or should i check it out...
