ATTN: Need feedback from tCs with HydraEMS
Old 12-30-2008 | 10:37 PM
  #421
rhythmnsmoke's Avatar
Music City Scions
^^yeah...LOL.
Old 12-31-2008 | 03:02 PM
  #422
ippskidder's Avatar
1UP Crew
Rhythmn aren't you an engineer?
lol
Old 12-31-2008 | 03:31 PM
  #423
Music City Scions
lol
Yes....Computers bro, computers..... shut up..
Old 12-31-2008 | 04:13 PM
  #424
Ace83's Avatar
Ronin Scion
i thought you are spraying nitrous at idle lol..
got i got improvements on spark map, nothing below 38 degrees on vacuum except in the idle area.. im gonna try it in a lil bit.
Old 12-31-2008 | 04:53 PM
  #425
ippskidder's Avatar
1UP Crew
tell us how it goes ^^
Old 01-01-2009 | 11:28 AM
  #426
Ace83's Avatar
Ronin Scion
nah i had to much too much advance on the lower 1-2 rpms, it pulls right away but since i have the to advance gradually as the rpms go up the car feels sluggish starting at around 2250.. im gonna data log again
Old 05-23-2009 | 05:32 PM
  #427
Ace83's Avatar
Ronin Scion
Yea let me do all the work.
Lazy a s s, jk bro =)
What size turbo do you have?
I understand how to change the timing, and how it works. I just want to do some more research for a few more days. So I can try it out over the weekend.
If my theory is correct. I should have less lag, and better midrange powerband, at the expense of some top end.
Which is ok, because by that time the turbo is screaming ^^
hey did you get the cam timing tune figured out?
Old 05-23-2009 | 06:42 PM
  #428
equinox2355's Avatar
I am still waiting to do my tune Darn ecomony and me not being able to afford the tune.
Old 05-23-2009 | 11:55 PM
  #429
Ace83's Avatar
Ronin Scion
at least your afforded the hydra lol.. me too cant afford to rent a dyno
Old 06-20-2009 | 07:14 PM
  #430
I am selling my hyda now my car is totalled (Luckily the HydraEMS was not installed yet)
https://www.scionlife.com/forums/viewtopic.php?t=263073
Old 06-20-2009 | 11:14 PM
  #431
Ace83's Avatar
Ronin Scion
oh damn sorry to hear that.. thats a 2.6 right?
Old 06-21-2009 | 02:54 AM
  #432
Yep its a 2.6
Old 12-26-2009 | 02:50 PM
  #433
Ace83's Avatar
Ronin Scion
I've heard the hydra 2.7 when it comes out will give you the option to use the gm flex fuel sensor and trim maps.. very nice for e85 users
Old 07-01-2015 | 06:32 PM
  #434
skruff's Avatar
Not really, lol.
I pinpointed a possible problem.
I have PE 800cc injectors, at 14 volts the lag is 1.6 ms
I compared it to others injectors of similar size (800cc), and their lag time is 1ms or less. So basically they open/closer faster than mine.
I got my car to idle, but when I lower the pulse width, it dies if its anything leaner than 12afr.
I wanted to change the injector latency map, so it can be close to what my injectors actually are. But the latency map only goes up to 1.2ms
So that doesn't help.
The only other possibility I see, is to go with low impedance injectors which usually have much lower lag.
I'm probably going to go with RC Engineering 750cc low impedance, denso style injectors. The lag time I think is something like 0.8ms at 14volts. Which is super faster than mine.
So with those I should be able to idle a lot better. So i'm gonna purchase those next paycheck, and then take it to get tuned.
N/A cars turned Turbo cars are a lot of work >.< !!!
RC Engineering:
Flow CC/min 750
Flow LB/Hr 71
Ohm 12
10v 1.36
11v 1.12
12v 0.92
13v 0.76
14v 0.63
15v 0.50
Old 08-10-2015 | 06:00 AM
  #435
Ace83's Avatar
Ronin Scion
wow back from the dead
WRX1316_TcVicent
07-22-2021 07:06 PM
PseudoKirby
03-28-2016 09:45 PM
a23r
02-01-2016 05:05 AM
AMS13
08-28-2015 08:05 PM
Subaru86
07-31-2015 05:33 AM
