Automatic SuperCharger Fit Kit - Released Dyno #s on pg 20
#344
thanks! i dunno if/when im upping boost. first imma wrap the header unfortunately, i wanna try to reduce as much heat soak as possible. then gauges and tune with greddy ultimate. then from there i'll see.
#345
excuse my ignorance as i do have a header and plan to get the TRD SC as well....heat soak...?...someone please explainit to me...does it really have that much of an effect on the trd sc performance? please let me know caus ei actually have a....hindes under a rock....creeps outs and dares to say....I HAVE AN A/T....hides under rock again, lol.
thanks....too many pages to look through to find out what it is....
#346
well cooler air running through the engine will perform better then warmer air. its the same concept i think. all the engine heat and alot of it coming from the header makes it a very hot environment under the hood. all that heat warms up the s/c and all the air running through the s/c gets warmed as well. i noticed somewhat of a difference between flooring it 2 minutes after i started the car, and 45 minutes after driving it.
#348
Heat soak is horrible on the s/c. I lost about 10HP on the dyno if I did a consecutive hot run. I had to let it cool to get the best numbers. The heat keeps you from building max boost so you lose power. Cooler air is denser and can hold more oxygen which helps the burn process and allows you to make more power. Hot air...not dense...cannot hold as much oxygen.
#350
no FMIC, its not worth it on the S/C, you lose more than what you would gain
and why are you under a rock? are you ashamed of having an automatic?
aw poor guy do you not realize the signifigance of having a free hand while driving with your date in the passenger seat?
some people just aren't smart enough i guess...
#351
#353
^^lol!
pete, gimme some time to break it in first!
yeh no FMIC. you lose a lot of boost with that and like gjpjr said, its not worth it on the s/c. i was thinking of doing water to air aftercooler. i think kytc is doing that to his, im waiting to see how it turns out.
#354
You know you can't deny my logic, its just too infallable.
just remember our goal ladies and gents... get SCOTTY some numbers!
#359
if you're doin some daily driving, you dont feel much of a difference because its a linear increase. you feel it pick up a little quicker though. some jerks if the ecu decides to shift close to the sweet spot. i've only put it at WOT twice and both were very satisfying . but like i stated before, the heat soak hindered the second WOT.
#360
was in Nemesis' ride yesterday...the pull is cool, but after riding the Cobalt Supercharged, It will be hard to like something less than the Cobalt Supercharged.
The RSX-S is still faster than the Cobalt SS Supercharged, but it isn't even Force inducted, so does that mean that the RSX-S can even take on and beat stock SRT4s, Supras, Evos?
