Automatic SuperCharger Fit Kit - Released Dyno #s on pg 20
Old 07-22-2006, 03:02 AM
  #501
kytc's Avatar
Oh man, that was on a dynojet as well. I'm glad somebody finally got it done and dynoed. You need to get about 5 grand together and come up here to KY and I'll help you get that badboy pimped out.
Honestly though I think you should pick up the spearco water/meth kit and take it to a good dyno shop and that should help a lot, Especially with spikes (even though your spikes go up instead of down?)
kytc is offline
Old 07-22-2006, 03:04 AM
  #502
05-RS1's Avatar
lol another 5g's?!?! i only plan to putting mayb half of that to the s/c..and definitely not droppin it at the same time lol.
btw did u dyno ur's after phase 1?
and i am looking into the same cooling system as you..but like i said..im not financially ready to drop that much at one time =\. ultimate is next for me.
05-RS1 is offline
Old 07-22-2006, 03:05 AM
  #503
kytc's Avatar
I would bet that with a midpipe to finish the exhaust and a 9lb pulley you'd be over 200 whp.
I'm dynoing mine Friday (1 week) along with getting the ultimate and injectors put on.
If you need any help with anything or any questions hit me up in a pm and I'll be glad to help you out.
kytc is offline
Old 07-22-2006, 03:15 AM
  #504
05-RS1's Avatar
sweet, i look forward to seeing ur results. after the dyno i thought about everyway to squeeze out extra horses. i'm tryin not to change the pulley. soo i gotta find time to cut my injen cai and try to install that..i want to do the midpipe but i dont want to have that change the exhaust note. then mayb injectors and ultimate. then try to go for a long time without modding to save up for that pwr intercooling system. i think im buying ultimate within the week.
05-RS1 is offline
Old 07-22-2006, 03:21 AM
  #505
kytc's Avatar
If you did do a midpipe, the ultimate, and the intake I would guess you'd be in the 190-200 whp range. That's a rough estimate though. If I were you I wouldn't do injectors, the s/c ones will flow fine without a pulley upgrade and it will save you about $400.
kytc is offline
Old 07-22-2006, 03:24 AM
  #506
kytc's Avatar
If you'd be interested I'll probably be selling my midpipe here in about 3 or 4 weeks to get the s-pipe back draxas. It's 2.5 inch with two resonators in and I've got a cat at home I could send with it as well. If you're interested pm me and I'll keep you updated.
kytc is offline
Old 07-22-2006, 03:25 AM
  #507
TongMan's Avatar
I just realized that i can spend about $600 and get around 20+ whp with the MMW header and s-pipe RATHER than spend $4,000 and gain only around 30+ whp!
TongMan is offline
Old 07-22-2006, 03:40 AM
  #508
TheQuietThings's Avatar
30whp??
stock auto tC dynos at 127whp ~5whp
170 - 127 = 43WHP = 50BHP
TheQuietThings is offline
Old 07-22-2006, 03:50 AM
  #509
05-RS1's Avatar
^^what he said. i think tongman was getting 30+ because my previous dyno was 141 whp WITH i/h/e. tongman, you have to take into consideration that the s/c works with those mods, doesnt just tack on more power. for example, if i upgraded to the MMW header, it may just add only a total net of 10whp. get it?
05-RS1 is offline
Old 07-22-2006, 03:58 AM
  #510
gjpjr84's Avatar
im sorry your disappointed 05-rs1, i guess i should be too.
honestly I am neither happy or disappointed,
I am still doing it, i was in it for a reliable daily driver with some umph. i call 40hp some pretty good umph
and also something is itching the back of my head about that dyno graph....
but lets look at it this way:
think about how much is lost with the auto tranny, now look at what the dyno shows for an auto s/c and think about the numbers manuals are getting and figure the difference between the 2......
but then you do have a header?!
i think something was up with the dyno, and knowing how much the S/C heat soaks and how hot its been.....
meh, my head hurts, i'll have some stock numbers in the fall when its cooler, like 97 degrees.
gjpjr84 is offline
Old 07-22-2006, 04:16 AM
  #511
05-RS1's Avatar
yeh im was in it for the reliable daily driver with the umph too and that was the overall reason for me s/cing rather then turbo. and yeh i have the AW header..prolly contributes to much of the heatsoak too. i have my header wrap but i need some metal zip ties that wont melt on the header. i was considering upgrading to the MMW but i think i wont do that for now.
and yeh, the dyno is kinna weird..i'll try to work somethin out with jason for a re-dyno...the guy did make a total of 6 runs on my car, 5 being nonstop, the other he let it cool down for like 5 minutes.
05-RS1 is offline
Old 07-22-2006, 04:18 AM
  #512
kytc's Avatar
Instead of doing the zip ties get you some good silicone and if you wrap it tight you can attach the wrap ends to the rest of the wrap with no problems and no ugly ties on it. I did it on mine and it worked perfect.
kytc is offline
Old 07-22-2006, 05:03 AM
  #513
05-RS1's Avatar
hmm i might do that..
05-RS1 is offline
Old 07-22-2006, 05:08 AM
  #514
05-RS1's Avatar
btw, wat size is the TRD injectors. Kytc, do u happen to have the ecu wiring diagram? that would help a bunch.
i'm gona help John get rid of this "auto tranny handicap". goal is 230whp, and high 13's or low 14's.
David will help u john. we just gota "invest".
05-RS1 is offline
  #515
gjpjr84's Avatar
that does sound like a much cleaner solution.
gjpjr84 is offline
Old 07-22-2006, 05:09 AM
  #516
kytc's Avatar
TRD injectors are 440's and let me check, I'm sure I've got the diagram somewhere
kytc is offline
Old 07-22-2006, 05:10 AM
  #517
kytc's Avatar
Yeah, I found the diagram, give me an email address and I'll send it out
kytc is offline
Old 07-22-2006, 05:39 AM
  #518
05-RS1's Avatar
pm sent. thanks for ur help kytc!
joe has high goals for me lol. the goal i set after the dyno was 200whp
05-RS1 is offline
Old 07-22-2006, 05:41 AM
  #519
gjpjr84's Avatar
sure does. shoot i am not wanting to get passed 200whp at all!
gjpjr84 is offline
Old 07-22-2006, 06:03 AM
  #520
Yanki01's Avatar
still watching...
Yanki01 is offline
Quick Reply: Automatic SuperCharger Fit Kit - Released Dyno #s on pg 20
