back in action
heres an old pic. its plugged in to the intercooler piping between the bov and throttle body. as far as a 50/50 mix. thats up to you. ive already been through a long disscusion on this forum about how i feel about putting something that doesnt burn through your cumbustion chamber.
block is sleeved by golden eagle, cp 8.5:1, carrillo rods, acl rod and main bearings, arp head studs. yes the car is on 100% meth. im actually using the meth to help with the fueling. my rc 650cc injectors would only support up to 12psi because the aem ems won't let you push them past 82% duty cycle as a saftey measure.
as far as track numbers. you should know better mike. remember who you're talking to.
So there is still alot left in this thing. Throw some 1000cc's in there.
big power on them LOW comp. pistons.... Its odd that Mike aka Elavationtc on a 35r only did 365whp or something like that on stock motor which is 9.6-1CR. Well brett i'm going to say it again congrats on the dyno numbers also was this in 4th or 3rd gear? gotta see the track times to be a believer sorry bro.
damn u got a stage3 wheel in the 60-1? i got a stage 5 :o hehe but only a 63 housing, brett come to this BBQ at the shop we should have some boosted tc's here
https://www.scionlife.com/forums/sho...d.php?t=170591
marcelo comin, and maybe pete to
You get more top end with a stage 5 and it's a bit laggy then a stage 3 or 1. But that's cause you have more top end. Plus a stage 5 has a bigger inducer and exducer which gives you more air flow. Just some 2 cents for you Chad.
Welcome back to the land of the living brett. Nice numbers to.
Funny thing, I just read about that in this months Modified mag. The only thing negative they had to say about 100% meth was that it acted as a fuel so it significantly changed the overall A/F ratio. If you have easy access to 100% meth, then cool I guess. But I don't know to many places that carry 100% meth. I would have to most likely have to order it to get full meth.
well down here in miami there is a place called Murrays speed shop which carry in stock meth and c16. also there is a vp racing gas station like 30 minutes from me with like 3 different pumps or race gas and carry Meth. so i mean i have easy access just the cost is not so good cause i do use a decent amount of meth lol. a 5 gallon can is like 35 bucks i think something around that price. i dunno i might just have to try 100% meth but i think i am gonna go from 50/5 to about 70%meth/30%water. see how that goes.
also as far as methanol goes it gets the AFR richer right not leaner? cause i know i tuned my car and it was at high 11's now its at mid 12's at WOT! could it have been i didnt put enough meth in my mixture?
Meth increases your octane level so A/F should be richer when added.
