Balance Shaft Removal Kit
#141
Originally Posted by xezerax
ok cool thanks, im thinking about doing this next week at work, i didnt wanna try to mig my block so ill try the jb weld
#143
Originally Posted by CRAracer05
I really want to do this,just a little nervous about my 07 dd u know? I think i would just bolt a plate with some sealant over the oil passage.
#144
Scion Tuners
my motor will be out for a few more weeks, so we tapped the hole to match a bolt out of an old monte carlo (LMAO) and JB welded the threads as we put the bolt in. NO oil will get throught that b. hahaaaa
#145
This might be a n00b question. But it looks as if the balance shafts can be removed without taking out the engine. Just pop off the oil pan, remove the balance shaft covers (8 bolts), and then remove the shafts?
Is there an oil pump in the way?
Are the balance shaft bearings easy to remove?
Can I JB weld both sides of that hole (with the engine in)?
#146
#148
Basically, the oil pump is in the way but you only need to remove the oil pickup tube!
Yes, the balance shafts bearings are very easy to remove.
NO, you cannot JB Weld both sides of the hole with the engine in. In order to do that you will need to remove the upper oil pan and it is "nearly impossible" to do that with the engine in.
Pito
#149
Scion Tuners
Originally Posted by przemko
and what might happend if you don't plug that hole or the jb weld would hold it..
fur_pig
03-20-2020 04:28 PM
rain7905643
03-14-2015 12:48 AM
NonStopTuning
01-20-2015 05:20 AM
