Base map for F/IC?
Base map for F/IC?
Could someone help me out and give me something to start working from? I am running a 6 PSI spring, stock injectors, and Garrett 16g turbo. Email it to evan.petito at yahoo dot com please. TIA
youll be better off running it how it is rather than a base tune
its 6 psi on a 16g u can run that forever with no issues now go to your tuner and tune for better gass mileage if u need, a base map form others will only cause u to have a ____ty scetchy tune
well if you want a basemap give dezod a call, they built one for me when i was s/c'd with the f/ic and the car ran pretty smoothly give them a buzz and they'll ask you for your turbo specs, supporting mods etc. and they can email you a map for a small fee but its worth it, do not run it forever though, use it to get you by till you can get tuned properly gl
I'm just going to tune it myself until I am ready to up the boost. I have the F/IC now, so I might as well use it and learn how to use it. I'll be taking it to PTuning to get it professionally tuned when the timing is right.
umnitza
09-01-2015 08:06 PM
