best sparkplugs
Old 05-09-2007, 12:46 AM
hotwheelsrs1's Avatar
man i was gonna gap mine, and i made the comment at the parts shop and she said they will break, so how did u gap them?
hotwheelsrs1 is offline
Old 05-09-2007, 12:49 AM
1UP Crew
Crippie's Avatar
good question.. is there a different gapping tool?
Crippie is offline
Old 05-09-2007, 02:14 AM
mikescion's Avatar
took the gaping tool and taped plugs and was careful
mikescion is offline
Old 05-09-2007, 02:26 AM
malloynx's Avatar
feeler gauges
malloynx is offline
Old 05-09-2007, 03:57 AM
Garage1217's Avatar
Originally Posted by Garage1217
No they are set at .032 if you order denso's. You have to use a feeler gauge set and bend the arm, not touching the iridium tip to gap them. A slide gapper will damage iridium plugs.
Just posted that info on page 1
Garage1217 is offline
Old 05-09-2007, 05:01 AM
lol sorry, man that sound like a job that takes a steady hand and alot of patients.
Old 05-09-2007, 05:23 AM
TeeCizzle's Avatar
Am I right then??...tC comes stock w/ Iridium plugs??
TeeCizzle is offline
TeeCizzle's Avatar
Old 05-09-2007, 03:15 PM
Garage1217's Avatar
Yes, yes you are right Most all new imports come stock with long life IFR series iridium plugs, which is a VERY good plug. N/a people with mild mods have no reason to change the plugs.
Old 05-23-2007, 02:43 AM
1UP Crew
Crippie's Avatar
Hey all.. finally change my sparkplugs and put in the NGK 7s in. Ill test drive it tomorrow, but it was idling fine. Attached are two pics i took of the plugs i removed. What i noticed and im hoping it comes out in the pics is a bit of oil on the threads, and some scorching around the tip of the plug. Anything to be worried about? I recently had an oil leak when I added the Oil pressure line with a fitting that didnt exactly fit, so I did have oil on the side of my engine, and a few days after that, my oil cap popped right off and sprayed oil everywhere. Think oil might have gotten into the plug area? Anyway, here are the pics... let me know what you guys think.
Crippie is offline
Old 05-23-2007, 06:05 AM
Bakemono's Avatar
Id go with Denso or NGK Iridiums.
Bakemono is offline
Old 05-31-2007, 10:47 PM
1UP Crew
Crippie's Avatar
update: After swappin my plugs for NGK 7s, i noticed idle was great, but FT was buckin on me. I regapped plugs and now it idles richer than it was before, but FT is where it used to be.... any thoughts?
Crippie is offline
Old 06-01-2007, 01:18 AM
malloynx's Avatar
what was the original gap. if the gap is too big your going to get spark blowout.
i guess when you tighten the gap the idle got poor but the bucking stopped. you need to find the middle point.. where is your gap now. id shoot for a .031 gap and make sure not to use one of those crappy plug gappers. get a nice set of feeler gauges.
if your running hella boost run a .28 gap or lower and run an HKS DLI.
malloynx is offline
Old 06-01-2007, 02:46 AM
Garage1217's Avatar
Under 12psi in a tc & iridium plugs run .040, already been testing it and it works fine. over 12 psi I would go down to .032 and no thinner. That should be good to 25psi+ without issues on our cars.
Looks like you got oil in your spark plug tubes. No worries. Also your plugs look normal, no worries there either.
Old 06-01-2007, 03:05 AM
Brett's Avatar
i was runnin 2 steps colder, .025, at 18psi
Brett is offline
Old 06-01-2007, 03:12 AM
Garage1217's Avatar
With iridium there is 0 need to gap down to .025. These are not junk v-power or nickle tip plugs "aka copper" That is the beauty of iridium, you can run a wider gap without risk of spark blowout.
Put it this way, on a 1500whp supra, my buds run .032 at 2x+ more boost than your running
Old 06-01-2007, 03:15 AM
Brett's Avatar
mine are ngk iridium. mabey my tuner thought that they needed that gap because my turbo maxed out at 14 psi??
Brett is offline
Old 06-01-2007, 03:19 AM
Garage1217's Avatar
Your turbo peaking out at 14 psi would have nothing to do with spark plug gap.
Old 06-01-2007, 03:20 AM
Brett's Avatar
dont know what to tell ya man. he gaped them that way, and i trust him alot with my car.
Brett is offline
Old 06-01-2007, 03:27 AM
Garage1217's Avatar
Nothing wrong with that tight of a gap other than you risk a crappy burn / unburnt fuel.
Quick Reply: best sparkplugs
