best sparkplugs
Old 06-01-2007, 03:33 AM
  #41
Brett's Avatar
Originally Posted by Garage1217
Nothing wrong with that tight of a gap other than you risk a crappy burn / unburnt fuel.
thanks for the advice. i'll let my tuner know when he tunes my new kit here in a couple weeks. i know he put it like for a reason. but i will most definetly bring the subject up, and see what he can do.
Brett is offline
Old 06-01-2007, 03:46 AM
  #42
Garage1217's Avatar
Cool. Yeah people that are used to running junk plugs do not know how to work with iridium. Whole different ballgame
Garage1217 is offline
Old 06-01-2007, 03:54 AM
  #43
Brett's Avatar
oh im sure hes knows what hes doing with iridium plugs. he has sevral 9 sec cars. it just not everything is so cut and dry. what works on your friends monster supra might not work on my car. im pretty sure that there is no magical .032 gap setting, just like there is no magical safe boost setting. there are just too many variables that differ from car to car.
Brett is offline
Old 06-01-2007, 04:03 AM
  #44
Garage1217's Avatar
Of course but if you are having spark blow out at 14 psi on a tc, you have major ignition issues. Of course there is no magic gap, used that as reference as no ignition system is the same either. Going down under .030 with iridium is just pointless because the "point" of running iridium is being able to run a wider gap without spark blowout issues. I see many old school tuners that know there shiz doing exactly what your guy did with your iridium plugs. Not that it is wrong, it is what they know from experience with older style junk plugs. Just have to have a different way of thinking with new equipment that is all.
And yes I know what I am doing with plugs, I had an odd nitch business for around 3 1/2 years of selling nothing but different kinds of spark plugs to race teams & tuners worldwide. From gold paladium, to iridium, to R series race plugs and even junk 1.1mm nickle tip plugs., I sold them all and know them all well. Was a lot of fun For your tc under 20 psi on stock ignition, I would never recommend anything tighter than a .032gap.
Old 06-01-2007, 04:08 AM
  #45
Brett's Avatar
dont get me wrong man. im not trying to insult your inteligence. and im sure that when it comes to spark plugs, you know waaaaaayyy more than i do. all im trying to say is. have you ever tuned a tc on 18 psi?
Brett is offline
Old 06-01-2007, 04:13 AM
  #46
Brett's Avatar
i geuss i may need colder plugs again.
Brett is offline
Old 06-01-2007, 04:34 AM
  #47
Garage1217's Avatar
All good man Hope the best with your tune and car. Turn some good numbers!
Old 06-09-2007, 05:38 AM
  #48
nlombardi1's Avatar
where do i order from??
nlombardi1 is offline
Old 06-10-2007, 09:17 PM
  #49
satoman44's Avatar
sparkplugs.com or ^^^garage1217.com
anyway, what is spark plug blowout and how do i know i have it? cuz im still not getting optimum WOT performance. it feels like the car is pulling timing and will run rich. when the motor is cooled down, the map keeps the afr at around 11 so i know the tune is not the problem.
my idle was crap when i threw in my plugs but it was because the gap was .030 or under. i regapped them to about .040 and the idle problems are fixed but the WOT problems are still there. im running one step colder plugs btw. should i go wider to stock gap?
satoman44 is offline
Old 06-12-2007, 05:14 PM
  #50
Basstrack17's Avatar
when our daughter took the wife's tc to her friend's shop recently and had it dyno'd, he told her that we needed new plugs. Now after some good advice ( thx to garage1217 ) I have ordered them; but since i didn't notice any real issues with how it performed before can I assume that with new plugs the dyno numbers wouldn't really change any? Do "correct" plugs make any difference "numbers" wise or is it more in feel and overall response?
Basstrack17 is offline
Old 06-12-2007, 08:51 PM
  #51
Garage1217's Avatar
There is a lot of false info on plugs on the market. See plugs themselves do not net any hp. However good plugs can react similar to an upgraded ignition system especially ignition systems that are weak in older cars. On the tc, we have a pretty darn good cop ignition system.
- If you were going from stock iridium plugs to new iridium plugs and the car had lower milage, chances are you would not see a difference at all on the dyno
- Seeing as your daughter has the TRD sc setup and knowing how utterly crappy the plugs are TRD provided, yes there is a chance you will notice a difference at idle, and highter up in the powerband as well. Nothing major but a few hp.
- Also iridium plugs generally last over double to almost triple the life of standard nickle tip plugs. Generally you should get 65K miles + out of a set.
Old 06-12-2007, 08:58 PM
  #52
Garage1217's Avatar
When the car is hot, what is your a/f? You say it is around 11 when it is cooled down... is that under WOT..?
Old 06-12-2007, 09:14 PM
  #53
satoman44's Avatar
Yes, 11 under WOT. but when I run it right after that, in the upper rpm range, it feels like im getting misfires or the ecu is pulling timing and I notice the afr dip to 10 (the lowest the aem reads so its probably under?)
Old 06-12-2007, 09:20 PM
  #54
Garage1217's Avatar
Actually if it is pegging the wideband at 10 then it is most likley much richer than that and you are choking the car down with fuel which feels similar to timing being yanked hardcore.
Old 06-18-2007, 04:23 PM
  #55
Racersky's Avatar
do i have to get sparkplugs made specifically for the tc or are the universal?
Racersky is offline
Old 06-18-2007, 05:03 PM
  #56
Garage1217's Avatar
They are not universal, and they are not 100% specific.
Old 09-01-2007, 02:22 AM
  #57
etsnet's Avatar
Should I get the BKR8EIX or BKR9EIX. Will be running turbo, built short block, 15psi+, 350-400whp (hopefully).
etsnet is offline
Old 09-01-2007, 02:25 AM
  #58
brett561tc's Avatar
i cant wait till you and aj's car's are done. we'll have to start some sort of south fl built motor tc club.
brett561tc is offline
Old 09-01-2007, 02:58 AM
  #59
etsnet's Avatar
It will be cool to pull up to the track and be like "oh it's just turbo at about 8psi". Then go run 12s and under. I think AJ will have a little bit better all around setup at first but if the traction isn't there it won't matter.
etsnet is offline
Old 09-03-2007, 01:42 AM
  #60
etsnet's Avatar
??? Anyone???
etsnet is offline
Quick Reply: best sparkplugs
