The best/worst 16 hours of my life...
I was on craigslist an found an ad for a built 2azfe being sold by a race shop. The only problem is that the Motor was located In Tuscon Az, and Im in Los Angeles. I just came back from the worst turn around of my life. Took almost 8 hours to get there, I ate a burger and Drove Back 8 hours.
The block has:
Cp pistons (9.0:1 compression 89mm)
Carillo rods
ARP main studs
ACL main bearings
ACL rod bearings
Tapped oil pan
0 miles, everything is completely balanced and ready to go.
Oh ya the best part...... I got it for $1100
I need a bunch more parts to get the motor finished but at least this is a start
You jelly brah?
The block has:
Carillo rods
ARP main studs
ACL main bearings
ACL rod bearings
Tapped oil pan
You jelly brah?
Thanks a lot guys I cant wait to get the built going
I already have the components for the head.
BC cams, Valves, and Valve Springs/Retainers and a spare head
The last big thing I need is a standalone
Thanks everyone
Now, Any advice on installing a block guard?
I noticed many other members here have a block guard installed.
If I decide to install one, I would need to get the block re-checked to make sure the cylinders are still in their proper position correct?
rvascion
11-12-2020 03:23 AM
BlingSlade
09-05-2015 08:52 AM
