View Poll Results: Which of these 2?
TDO5H-16G-10CM2
42.86%
TDO6H-20G-TDO5H-10CM2
42.86%
other...
14.29%
Voters: 7. You may not vote on this poll
Which is better for a custom setup?
Old 05-17-2006, 10:28 PM
soros151's Avatar
Originally Posted by SO-CAL_TC
Hmm. well this is my first time going turbo so any more suggestions would be greatly appreciated.
You don't have to change PSI levels when it's that low. If you were talking like 8-10psi daily and 15psi at track, then I would be like cool....but 4psi and 7psi, not enough to warrant driving daily on. My girl drives daily on 8/9psi.
Thanks for info. Learning something new everyday :D
soros151 is offline
Old 05-18-2006, 01:19 PM
bbsciontc's Avatar
7psi is pretty much the minimum and is determined by your wastegate spring
bbsciontc is offline
Old 05-18-2006, 06:53 PM
soros151's Avatar
If the wastegate (spring) determines the amount of psi that will be used, then how do we determine with a boost controler the amount of psi we will use. Does the spring also has to be changed or do we leave the spring (7psi) and add the boost controller? Very confused about how to control it.
soros151 is offline
Old 05-18-2006, 07:13 PM
zer0's Avatar
I believe with a Boost controller you can double and a half what the sping is being run.. At least that is how it is on my Greddy Profec Type S
zer0 is offline
Old 05-18-2006, 07:18 PM
soros151's Avatar
So if I'm running a 7psi spring, The with a boost controller I would be doing 14psi? Is that what you are saying?
soros151 is offline
Old 05-18-2006, 08:10 PM
SO-CAL_TC's Avatar
What he said?
SO-CAL_TC is offline
Old 05-20-2006, 10:35 PM
soros151's Avatar
bump
soros151 is offline
Old 05-24-2006, 08:30 AM
soros151's Avatar
bump, need an anser on this. any help appreciated.
Still no answer to this? dang... I will never know.
soros151 is offline
SloTC1
08-16-2018 02:45 PM
torqueTc
10-08-2015 05:39 PM
vi3tb0i09
09-23-2015 08:32 PM
Subaru86
09-14-2015 12:51 PM
xBrelease08
Scion xB 2nd-Gen Wheel & Tire
09-13-2015 04:39 PM
Quick Reply: Which is better for a custom setup?
