Blow Off Valve vs. Mass Airflow Sensor...DA DA DUMMMMMM
Old 05-09-2008, 06:05 AM
tC_2NeR's Avatar
Default Blow Off Valve vs. Mass Airflow Sensor...DA DA DUMMMMMM
In a nutshell,
Is my car gunna suck not recirc'ing the BOV?
tC_2NeR is offline
Old 05-09-2008, 06:20 AM
Ronin Scion
Ace83's Avatar
mine did fine but yeah the maf goes crazy when bov opens.. maf is one big enemy for piggyback too.. and make turbocharging a lil tricky..
Ace83 is offline
Old 05-09-2008, 06:22 AM
tC_2NeR's Avatar
did ur car stumble or stall when say u were in boost then hadda hit the clutch for some reason? cause i heard of cars shutting off when hittin the clutch while in boost
or does it stumble between shifts?
tC_2NeR is offline
Old 05-09-2008, 06:26 AM
Ronin Scion
Ace83's Avatar
never stalled.. not sure what you mean by stumbled but the only thing i noticed is the hiccups or sudden jerk while cruising and afrs goes like up to -- then back to normal.. but between shifts the afrs does goes from too rich to lean and then goes back. proper tuning should help the problem too
Ace83 is offline
Old 05-09-2008, 06:28 AM
tC_2NeR's Avatar
ahhhh, thank you Ace
tC_2NeR is offline
Old 05-09-2008, 01:41 PM
Rydrdg's Avatar
my car shuts off when i hit boost a little, sometime it does that, rpm would drop down close to zero an engine shut off, i dont know but people say it might be the extra air goin back to maf....you thnk tuner can adjust somethng to work around that
Rydrdg is offline
Old 05-09-2008, 02:53 PM
tC_2NeR's Avatar
are u tuned?
tC_2NeR is offline
Old 05-09-2008, 05:56 PM
aen
aen's Avatar
tuner can actualy fix that
aen is offline
Old 05-09-2008, 11:13 PM
coryjames's Avatar
clamp it?
coryjames is offline
Old 05-09-2008, 11:58 PM
ScionERA
Nu_ERA's Avatar
Recirculation will make the car run much smoother IMO. MAF and atmospheric BOV's are a battle unless you go standalone. Though I think Emanage Ultimate has a MAF delete (so I heard)
Nu_ERA is offline
Old 05-10-2008, 03:25 AM
Soulquarian's Avatar
I was using an HKS BOV on my ZPI Stage 1.5 kit, and I had a lot of problems with stalling, throttle delay, etc.
I installed a Synapse Engineering Synchronic BOV and had 0 problems since. I didn't even tune with it. Just bolted it on, and all the problems went away.
I bought the HKS Flange and Anti-Stall kit. You can get the Synapse BOV at Prestigeracing.net
Soulquarian is offline
Old 05-10-2008, 04:27 AM
Ronin Scion
Ace83's Avatar
so what difference does that BOV from synapse engineering have, its still atmospheric right? i know they have an awesome wastegate but havent heard of their bov yet.. got vids to that? and what anti stall kit is that, what does it do? im pretty sure good tuning will fix stalling and maybe make it smoother but as nu era said, recircng will make it smoother but the better way is a standalone..and ptuning is also having a project with maf after bov and turbo that will help too.. curious to know about that MAF delete from the ultimate, havent heard anyone talk bout that
Ace83 is offline
Old 05-10-2008, 04:39 AM
I'm at work, so I can't access Youtube, but basically, the Synapse BOV is piston driven rather than Diaphragm driven. It eliminates compressor surge, boost leak, and many other problems that come from using an Atmospheric BOV.
Here's a link to their videos. When I get home, I'll post a video of the video that made me try out the BOV.
http://www.youtube.com/synapseengineering
Old 05-10-2008, 04:47 AM
Ronin Scion
Ace83's Avatar
nice, yeah post some vids.. how's the sound? and it does use the same flange as HKS?
Ace83 is offline
Old 05-10-2008, 05:12 PM
SoFloTC's Avatar
my car is auto and shuts off when im going slow (0-20) and then give it some good foot and let the bov go off and then stay off the gas... Japtrix said it was becuz i need to recirc the bov.
SoFloTC is offline
Old 05-11-2008, 12:12 AM
gompka's Avatar
i'm running some generic atomospheric bov i got on craigs list. also have a 9.5psi pulley. I have no problems idle, wot, or mid throttle.
gompka is offline
Old 05-11-2008, 05:32 PM
tC_2NeR's Avatar
BUMP
anyone else with a turbo tc around here???
some ppl are having trouble n some arent...just want more opinions
tC_2NeR is offline
Old 05-11-2008, 06:09 PM
SoFloTC's Avatar
does recircing the bov take away from the sound anyway?
SoFloTC is offline
Old 05-11-2008, 06:25 PM
FLIN-SCION's Avatar
has anybody checked out tial's new recirc BOV. Its called the Alpha Q or something. Supposed to be better than their old style atmospheric bov. just wondering
FLIN-SCION is offline
Old 05-11-2008, 06:30 PM
FLIN-SCION's Avatar
nevermind their not selling as of yet
Quick Reply: Blow Off Valve vs. Mass Airflow Sensor...DA DA DUMMMMMM
