blow thru maf
Old 05-10-2011 | 08:23 PM
kradstct's Avatar
Default blow thru maf
ok so im working on a turbo build of mine for a couple of years now and i here about using a blow thru maf setup with there emanage ultimate and i was wondering wat maf ur using if its just like on a eclipse gsx setup were they use a gm blow thru with a gm transducer
Old 05-10-2011 | 08:38 PM
trd07tc's Avatar
OEM
Old 05-10-2011 | 08:43 PM
kradstct's Avatar
wat do u mean by oem im looking to us a 3inch blow thru maf
Old 05-10-2011 | 09:12 PM
trd07tc's Avatar
get a flange weld it on your ic pipe and bolt on your OEM maf
Old 05-10-2011 | 10:21 PM
Ace83's Avatar
Ronin Scion
i agree oem
Old 05-11-2011 | 01:10 AM
OuterHeaven's Avatar
It is not like the DSM. Our MAF just bolts into a flange which you can weld to any size pipe but I would not recommend anything bigger then a 3 inch.
Old 05-11-2011 | 03:30 AM
athletefeet66's Avatar
where would one order a oem maf flange?
also if youre going from pull thru to blow thru is a retune needed?
Old 05-11-2011 | 03:59 AM
x_Batman_x's Avatar
2007-2010:
http://www.dezod.com/pd-sciontcmafflamge.cfm
or
2005-2006:
http://www.dezod.com/pd-scion-tc-05-...ge-adapter.cfm
and yes, the a re-tune will be necessary
mudguy
10-22-2015 04:31 PM
corbinortiz
10-02-2015 02:45 PM
Jus2tastee
10-01-2015 08:57 PM
vi3tb0i09
09-23-2015 08:32 PM
Gigs
09-15-2015 03:54 AM
Quick Reply: blow thru maf
