Blown turbo ??
Blown turbo ??
Hey guys i really need help and am fustrated. was driving all week on a solid tune at cruising speed and idle read 14.8-15.0afrs now at idle somtimes it reads in the 10s and 12s same is with crusing.................. i was driving the other day and it was reaidng 10 and all sudden heard a loud loud boom come out the exhaust continued to drive was fine sounded like i hit somthing, i dunno what to do if turbo is blown or this is somthing else. i deff dont think its the motor. when i hit the gas the turbine still builds boost but i dunno it seems a little laggy and somtimes it hestitates with the power. somthings deff going on checked the oil catch can and top my surprose there ws a good amount of oil in there for how long i put it in the car at least 3-4 oncues of oil. can i drive like this. till i save for a another turbo or dont drive it till its fixed.
Team No Limitz
check to see if theres shaft play on the turbine housing...take the turbo apart and see if oil blew thru the seals. Does the car smoke a lot while its running? You gotta be a lil more specific if you expect people to help you out. Start by trying what I said. There should be no more than an 1/8" of play on the shaft.
noo there is nooo shaft play a little smoke not bad but its winter soo all cars smoke a little then it goes away after the car is warmed up. but when i did take the intake off there was a few ounces of oil in the intake not bad but just a little....... cleaned it out and put it back on. but no there was not really any shaft play and if there was it was at a minimum, but i have had this turbonetics turbine on the car for year and half and all i hear is bad things about how the seals blow and there just crappy turbines, i might have to start looking into getting somthing new but what? i dont wanna go crazy just want somthing thats good and reliable. dont wanna spend too much as im in college now.
Team No Limitz
not bad not bad sounds good i think im gonna give hiom a call i think this turbo is whats causeing me to get these afr cause i believe it blown not the motor but the turbinesoo im gonna haver to baby my car till iget the new one put in.
Originally Posted by bash
Check all the pipe connections, mine did that when an ic pipe worked loose. really rich afr's and lower power.
What else is happening, just really low AFR's (10.0 - 12.0) even at idle?
- Check all Vac Lines
- Check Intercooler piping as well as all other piping
- Oil Lines
thats exactly what it did.... scared the poo outta me for a min.
Mine was on the 210 east last night around 11pm in dead stop traffic, and I had to take a leak so bad, it was fn awful. The pipe just was kinda hanging within the coupler, I guess with some of the air getting through. Hopefully Byta has a simple problem like that.
yeah, i wish it was that checked all vacc lines and oil lines all good, i also checked all couplers to make sure they were on tight and they were.... 2morrow im gonna take off the intake see if there is oil build up in the intake id say we all know what that means. I was driving tonight the AFRS were perfect i mean perfect then all of a sudden like 30 min of driving the afr shot right down to 12 then to 10 then to like 17 i was like what the hell, just picked this really nice girl in the car on a date first date, was praying to god i wasnt gonna get stuck on the side of the street, shes like whats all those gauges for and she was like my gf has this same car but why dont u have back seats or a spare haha i wanted to show her tc beast but i played it off well i only do that on the track and this is stock. cause my afrs were extremly rich halfway into the ride haha wanted to get her home in one piece without the car detonating and blowing us both up haha she like its smells like fumes at every light we stopped at. its deff not tune related i know this somthing is going on with the car itself, most likely turbo related , but i will double check vaccs again 2morrow. i also took out the emanage to check the tune and everything was perfect. reset the battery and it was fine until 30 min into the drive. those afrs jumping all over the place 10,12,13,14,all the way up to 17 then back down to 10 for a while maybe the gauge came loose try tighting the gauge bung hmmmm ..... Thanx again for the help guys -Matt
Double check those couplers. One time one of my pipes was just barely connected and I did not notice untill I took it apart. The clamp even seemed to be able to tighten. Also do you have any cel's?? Possible your front o2 could be going bad. Also make sure your maf is not loose or anything.
Re: Blown turbo ??
well there was a little oil in the intkae nothing really crazy just dumped it and put it back on .......... but i do have a cell and maybe you are right about the first o2 sensor going. hmm im gonna have the codes checked see which o2 it is. If its the secndary one then its ok but if its the first one u think this could be the reason for the AFR jumping all over mostly rich condition.... maybe some oil got on the sensor and ruined it. i dont think its the maf everything is plugged in correctly but ill try using some clenaer and clean the maf reset the ecu then try again... any other suggestions in the mean time?? anyone on longisland turboed ??
