boost contrler / vac lines.
I have been searching for bout an hour now and i cant find how to hook up the vac lines to a turbocharger. I have installed most of the turbo so far. Does anyone know how to install the vac lines and boost cotroler?
Doesn't matter what type of boost controller you have.. as long as you have one.
With boost controller:
Vacuum source (usually intake manifold or compressor housing) to T-fitting - one side of T fitting to boost controller -other side of T fitting to side of wastegate - top of wastegate to boost controller.
Oh yeah do you have an external wastegate, if remembered it right setting up on an internal wastegate to boost controller is slightly different but im speaking of the truboost which is a digital boost controller. And if you have a vacuum block, routing will be a little different but the principle is the same
crimson_sinn
09-25-2015 09:41 PM
DryToast
08-04-2015 02:59 PM
