Boost Creep Still!!
Have you tried dumping the wastegate to atmosphere. The issue may be an inefficiency in the way the wastegate dump is ported back into the downpipe. If there is a significant pressure build up at the point of merge the path of least resistance for the exhaust gas will become through the turbine as opposed to through the wastegate as it should be. Try dumping to atmosphere for a couple dyno pulls and see if it helps. If it does you need to route the wastegate return further down the exhaust path.
Originally Posted by Rasta
Originally Posted by ERIC-TC
Give us some details on your wastegate? Have you done a leak-down test on your vaccum lines? Do you recirculate the waste gate?
Originally Posted by mike6789k
Originally Posted by tc2nut4
good or bad interesting???
crimson_sinn
09-25-2015 09:41 PM
