Boost Gauge
Boost Gauge
Hi I wanted to install just a boost gauge for my supercharger is there DIY or could someone explain to me how to install it and is a cheap eBay boost gauge good enough ?
how to install the boost gauge itself or how to connect it !!!!!!!!!!!
you want a good accurate boost gauge,i personally would stay away from ebay...you get what you pay for..its very easy to hook up and install one
you can splice the power to your cig lighter fuse,theres a bolt underneath the sterring wheel,you can ground it to,if you look in the tech area,they will tell you exactly,where,but its all personal preference
to give you a idea..click on this link,and roll down the page to boost gauge install
https://www.scionlife.com/forums/tc-tech-diy-1818/gauge-install-autometer-27143/
I have my boost gauge installed down in the cubby hole in front of the short shifter. I wired it into the cubby light wire so when my headlights get turned off it also turns the light off in the boost gauge. I would reccomend that over the cig lighter. If you wire it to the cig lighter then you will always have it lit up.
SloTC1
08-16-2018 02:45 PM
crimson_sinn
09-25-2015 09:41 PM
